2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions Major Coding Problem. Lost Access To Hu_entry
      11-26-2014, 02:14 AM   #1
fkacct
Drives: 550i M-Sport --> 228i M-Sport
I started coding my 228i tonight and now I've run into a pretty bad problem. I was coding the headunit (HU_ENTRY) with some basic stuff and when the unit reset itself after pressing "CODE FDL," I got a German interface that doesn't seem like it belongs to my car. It has a bang&olufsen menu etc.
Below pictures should explain things a bit. I am now unable to access HU_ENTRY. There is no longer a CAFD with a green marker under the HU_ENTRY label.
Really hope you can help out with this. The only codes I recall messing with are:
3002 Radio_dab
3002 Dab_laendervarianten
3002 dab_standard
3002 following_available
3002 following_dab_fm
3000 EFF_DYN_SPORT_CID
3000 EFF_DYN_SPORT_UNIT
and I also changed the following (but they're under FEMBODY which remains usable):
Fembody 3070 Ambiente_Helligkeit
Fembody 3070 Ambiente_Nachfuehrung
Hoping ShawnSheriden or others can shed some light on this.
      11-26-2014, 03:18 PM   #2
Cybertronic
48
Drives: G30 M550i, E30 M3
There's something wrong (obviously) the diag address of your HU is wrong.
Do you have ISTA/D?
I would unplug your battery for a few minutes, and then reconnect E-SYS to the car, and see if it shows up.
      11-26-2014, 03:40 PM   #3
fkacct
Do you have ISTA/D?
I'll give it a try after work. Do you think injecting a CAFD and pressing "CODE" would do any good in case battery pullout doesn't work?
I'm a newbie at this so I actually have no idea what ISTA/D is...
      11-26-2014, 04:08 PM   #4
Cybertronic
48
Yeah, try to code the defaults on that module again. Its possible your voltage dipped during the code, and it doesn't have anything on it.
Are you using a charger while you code?
      11-26-2014, 04:17 PM   #5
fkacct
Cybertronic, I did not use a charger and also noticed that the car was off for
whatever reason after the error came on (or maybe I forgot to keep it running ).
I'm very new to this and trying to gather how to write a new CAFD. Can you confirm that these steps are good:
Connect => Read FA => Activate FA => Read VCM => Left-Click on HU_ENTRY => Click on "Detect CAF for SWE" => Select the CAFD matching your I-Level => Select OK => Right-Click on HU_ENTRY => Select CODE.
How would i determine what my I-Level is?
      11-26-2014, 04:48 PM   #6
Cybertronic
48
You don't want to code/program a car while its running.
The IGN should be on (cluster all lit up), but not running.
This is why you must have the car on a charger, or supplemental battery.
You can read the I-Level from E-Sys under VCM in Expert mode.
Click on the Master tab towards the bottom, then click the Read button in I-Steps.
      11-27-2014, 02:39 AM   #7
fkacct
Problem Solved. "Detect CAF for SWE" and "CODE" reset the unit back to its original settings.
      11-27-2014, 08:28 AM   #8
Delnari
Delnari's Avatar
Drives: 2014 MG F22 Auto
Nice job on the recovery. Interesting that it was recommended not to code while the car is running as I have done this many times during coding without an issue; thus far.
      11-27-2014, 08:48 AM   #9
bman6074
103
Drives: 14 M235i and 07 Lotus Exige S
+1 I have done 3 different cars this way without any issue.
      11-27-2014, 10:13 AM   #10
pikcachu
pikcachu's Avatar
1399
Drives: M235i (F22 Red angel)
it's OK as long you don't code the DME.... you can imagine that coding the engine while the engine is running might not be the best thing to do..
      12-01-2014, 07:54 AM   #11
nyeager
Drives: 2015 M235i xDrive
Take it from someone who actually did this exact thing... It's not fun, you get all kind of errors that look really bad like "drivetrain malfunction, fuel-system problem" etc.
Thankfully guys like Shawn and Pickachu are around!
      12-01-2014, 07:30 PM   #12
zipphreak
454
Drives: m235xi
What exactly does "Detect CAF for SWE" do? I understand CODE means program defaults, but I'm curious about what that portion of the recovery did.
      12-01-2014, 10:00 PM   #13
Cybertronic
48
Detect CAF picks the correct CAF file for that module. (CAF files being the base coding files)
Something you really only need to do if its missing.
      01-14-2020, 01:20 PM   #14
MarkyMark1111
Drives: Bmw 320I
Please Help!!
I recently my BMW F30 320I as per https://www.bimmerfest.com/forums/sh...96&postcount=7
This was so to enable bluetooth media. I lost all bluetooth options and DAB. I tried to revert the changes by starting again, but when I got to HU_ENTRY to select code it is now greyed out.
Any and all help would be great appreciated!
      03-11-2020, 03:11 PM   #15
Mawaz
Mexico
Drives: BMW M240i
Is that possible with BimmerCode?
      Yesterday, 05:56 PM   #16
RxSHAL
Drives: BMW 118i 2013
Saved a 1 series.
Bro, I needed to create an account to say that 10 years later your step by step saved my 6,5 CIC while I was trying to activate enhanced bluetooth and just flashed a 6NL HEX and my CIC became the most basic possible, not even USB worked. Obviously I had backup, but when I tried to flash, HU_ENTRY doesn't showed "CODE" anymore. Tried 20 times and nothing. Then I passed by your suggestion and VOILA! Worked to restore backup, sadly I still want to put bluetooth music at my F020-13-3-503. Any suggestions?
2addicts
