BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > bolt for the transmission oil pan
      11-24-2014, 02:26 PM   #1
csupernova
csupernova's Avatar
32
Drives: E90 330i
Are those bolts one time use only?
      11-24-2014, 05:41 PM   #2
mweisdorfer
mweisdorfer's Avatar
Drives: 2007 Black/Black 335i e90
2007 BMW E90 335i  [0.00]
2008 bmw x5  [0.00]
I guess it would depend on how many miles are on your car and how many times you have changed the trans fluid. They are not one time use.
      11-24-2014, 06:30 PM   #3
DJtoad
Drives: 2010 535i M Sport
Actually, I'm pretty sure they are one-time use since they're an aluminum alloy. If you have the older T27 head bolts, they tend to strip easily during removal which is why ZF later replaced them with larger head T40 bolts. If you have T40 bolts, a lot of people buy a few "just in case" and don't replace them since they're pretty pricey. The key is to carefully torque them to the correct specifications (believe it's only 6 ft/lbs but you should double-check to be sure).
2010 535i M Sport - Platinum Gray/Dakota Black/Anthracite Bamboo
2016 Jaguar F-Type S AWD - Polar White/Cirrus
      11-24-2014, 06:30 PM   #4
mweisdorfer
2008 bmw x5  [0.00]
Unless they have blue paint on the end, they are not one time use.
      11-24-2014, 07:46 PM   #5
DJtoad
Sorry, but that's incorrect. While all blue-painted bolts are one-time use, not all one-time bolts are painted blue. ZF makes the transmission, not BMW, and they don't paint the bolt heads. If they're aluminum, they're one-time use.
      11-25-2014, 11:52 PM   #6
Meeni
Gateropode
Meeni's Avatar
329
Drives: BMW 330i 06
Mine are rusted, so they are not aluminum (or at least not on all models). I have a 330i too. I'd replace only the rusted ones and reuse the other ones. They are kind of pricey at $3 per bolt and something like 24 of them oO
