Question about V2
01-08-2008, 07:27 PM | #1 |
148
Rep 1,738
Question about V2
I have V2 12-24 map, I have been driving for about 200 miles on 94% and am only getting 13-14.1psi, Is that normal? Can I turn it up to 96% without any issues? Im running 93 octane gas and V2 is my only mod.
01-08-2008, 07:46 PM | #2 |
اوليسيس
198
Rep 4,678
yes you can go up, but not by much, try 95 first then 96%. by your location i think you are at a higher elevation, though.
01-08-2008, 07:50 PM | #3 |
329
Rep 4,484
If you haven't seen a peak of higher than 14.1 psi in any gear while ACCELERATING, then yes, you can go above 94%....especially since you are on 93 Octane.
I'd punch in 95.3% and let it round it from there. If you peak in the 14.5-14.6 psi range, in the cold weather you should be good to go. Keep in mind, in the heat of summer, you may need to bump the values back down to 94% though to keep from going over 15 psi. Later |
01-08-2008, 10:22 PM | #5 |
442
Rep 18,331
I am running 95% with 93 octane and my peak boost is at 14.7 to 14.9psi....I am maxed out! Summer i will bring it back down to 94%...or unless V2.03 directs me another direction!!!!
01-08-2008, 10:25 PM | #6 | |
137
Rep 6,608
Regardless, I am impressed by the success of V2 boost control so far... |
