BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > procede v2 dyno expectation
      01-08-2008, 05:43 PM   #1
jgrigoros
jgrigoros's Avatar
Greece
19
Drives: F82 M4
hey guys i have a dyno scheduled for monday
and would like some feed back on what to expect.
currently i'm running 94% accross the board on 94 octane.
maybe it just me but it doesn't seem to have the same
feel as v1.45.don't get me wrong the car pulls very
strong but it doesn't seem to have the same
feeling in lower rpm's. any thoughts
i also posted the dyno results from v1.45
      01-08-2008, 06:02 PM   #2
Sniz
Sniz's Avatar
654
Drives: e92 335 - gone // e36 M3 turbo
well chances are your not making 400 lb ft w/ V2, it feels slower at low rpms, but its not.
      01-08-2008, 06:05 PM   #3
jgrigoros
jgrigoros's Avatar
Greece
19
Drives: F82 M4
so it makes less torque but more hp
      01-08-2008, 07:29 PM   #4
djrobroe
7
Drives: soon to b 335
wait so is this v1 or v2?
      01-08-2008, 07:30 PM   #5
jgrigoros
jgrigoros's Avatar
Greece
19
Drives: F82 M4
this is a dyno from v1. next week i will be going to dyno v2
just wanted some feedback on what to expect
and i should do any changes
      01-08-2008, 07:32 PM   #6
E90ice
E90ice's Avatar
205
Drives: 2008 335xi Coupe
You should make around 350whp.
      01-08-2008, 07:34 PM   #7
jgrigoros
jgrigoros's Avatar
Greece
19
Drives: F82 M4
that sounds great but will it compensate for the lower torque
at low rpm
      01-08-2008, 07:39 PM   #8
NPDAN
NPDAN's Avatar
95
Drives: AW DCT M3
2008 E92 M3  [8.00]
07' E92 335i  [0.00]
at low rpm
With the newer firmware and new maps on V2, it brings back a lot of the low end tq we had with the 1.47
      01-08-2008, 07:44 PM   #9
jgrigoros
jgrigoros's Avatar
Greece
19
Drives: F82 M4
im running map 12 24 with torque settings at 94%
but the low end torque doesn't feel the same
with v1.45 any gear you were in and pressed the gas
the car would take off. now you get that feeling only in higher
rpm range
      01-08-2008, 07:50 PM   #10
RiXst3r
RiXst3r's Avatar
274
Drives: M235i
more boost down low generates more heat up top. without other supporting freeflow or cooling mods its hard to get good power up high and down low...
      01-08-2008, 08:18 PM   #11
jgrigoros
jgrigoros's Avatar
Greece
19
Drives: F82 M4
so i should expect similar power from v2
without other mods
      01-08-2008, 08:37 PM   #12
O-cha
O-cha's Avatar
218
Drives: Mcoupe
Heat that would hurt up top, where what heat?
Don't say the intercooler because that's not true higher boost down low will create no significant "heatsoak" on the intercooler. The amount of heat that needs to be dissipated at low RPMs is a fraction of that at high rpms and is well within the capacity of the stock cooler at whatever we can put out.
      01-09-2008, 12:30 AM   #13
RiXst3r
RiXst3r's Avatar
274
Drives: M235i
when I said "up top" I meant by the end of the run... the longer the run, and the harder the turbos run early in the dyno run can effect the final top end hp at the end of the run in the top of the rpm band, you can see the same effect by running back to back runs. You might not see this on the road, but you can see it on the dyno, especially ones without proper ventilation
its been proven with some of the v2 dyno's that when you dial back the user tq settings down lown, you get more hp up to, because the turbos have not generated as much heat...
search for the v2 dyno graph collection thread... leftcoastman was the one that posted about lower tq settings down low gave him higher hp up top
      01-09-2008, 12:35 AM   #14
stillclaimndp
Dancing Machine
stillclaimndp's Avatar
Drives: 335i e90 ZSP
youll make way more power at 94% on 94 octane than that dyno but that was abnormal torque for 1.45!
2007 e90 & 1981 Corvette Predecessors: 2007 BMW 335i E92, 2006 M5, 2008 Viper SRT10 Coupe, 2005 Viper Yellow, 2006 Corvette Z51, 2009 Challenger SRT8, 2006 S4, 2001.5 Nogaro Blue S4, 2006 GTI w/ DSG, 06 Evo IX, 04 S4, 04 911x51, 03 Evo VIII, 98 Eclipse GSX, 96 GST, 92 Galant Vr-4, '70 Grand Prix Model J, '70 Nova, '68 Firebird
      01-09-2008, 08:39 AM   #15
jgrigoros
jgrigoros's Avatar
Greece
19
Drives: F82 M4
what is so abnormal about it. i would just like to know
it is to high for v1.45
