Strange noise coming from under the hood
11-21-2014, 03:02 PM | #1 |
396
Rep 735
I have this strange noise coming from under my hood after I lock my car and I have no idea what it is.
Found this clip online and sound is identical Running JB4 on Map 1 also
Current: 6MT F80 M3: KW V3 Coilovers | Savini Wheels | PSM Style Diffuser | CS Style Front Lip
Old: N55 E92 |
11-21-2014, 04:42 PM | #2 |
27
Rep 199
I believe it's the low pressure fuel pump priming.
happens when you unlock your car or open your doors or trunk... it primes to prepare for you to start your car. |
11-21-2014, 11:30 PM | #3 | |
396
Rep 735
Old: N55 E92 |
11-22-2014, 07:04 AM | #4 |
Libertarian
132
Rep 1,577
Agreed, sounds like a pump priming. BUT, it shouldn't take that long. Could it be something clearing the lines or a reservoir as a preventative measure of some sort?
OP, does it do this every time, regardless of ambient air temp and engine temp? My N55 makes noise too, but not like that...
2011 335xi Coupe BSM (e92/N55/ZPP/ZCW, Alpina B3 Flash)
Bought 08/09/2013@53,340mi Current 3/13/2019@206,283mi Fail(s): tstat hous/water pump 89k, Chargepipe 106k, coolant tank 114k, FRM3 114k Maint: Walnut blast 101k, Trans/T-case Fluid 103k, OFHG 195k |
11-22-2014, 07:08 AM | #6 |
Libertarian
132
Rep 1,577
His signature indicates a JB4.
11-22-2014, 11:21 AM | #7 | |
396
Rep 735
Old: N55 E92 |
11-22-2014, 11:22 AM | #8 | |
396
Rep 735
Old: N55 E92 |
11-22-2014, 11:48 PM | #9 |
396
Rep 735
Okay so my engine oil is okay, But I still have the sound whenever its measuring and I can only hear it outside when i lock the car the sound goes away about 2-3 seconds after. Should I make a trip to BMW?
Old: N55 E92 |
11-23-2014, 07:46 AM | #10 | |
Libertarian
132
Rep 1,577
Personally, I would: 1) Research as much as possible on the internet. If you find multiple sources indicating the same issue, follow that. You shouldn't go in a particular direction based solely on one post or advice from one person. 2) Find an indie who specializes in foreign cars / BMWs. They can have VERY reasonable labor hours, and will often give you good sound advice for free. 3) As a LAST resort, go to the BMW dealership. The dealerships are highly overrated and overly expensive. Plus, in my experience, are not as knowledgeable as your standard DIY guy. In your case, take the engine cover off and the acoustic cover off, and see if you can better pinpoint the source of the sound. Could be the water pump, could be the fuel pump, who knows. Is it making the noise while the engine is running as well as when it's not running? Do you think the car has been running any differently? You indicate it started happening after the oil light came on. Have you changed your oil lately?
11-23-2014, 11:35 AM | #13 |
396
Rep 735
I'm still under warranty and I do have extended warranty as well, so it looks like a trip to BMW is going to be the way to go. It's just strange because I think the sound only happens when it's measuring the oil level haven't had enough time to pinpoint it exactly
Old: N55 E92 |
11-25-2014, 12:26 AM | #14 |
396
Rep 735
Okay so its been fine the past 2 days, Now it says engine oil low again.. But there are no leaks from under the car either. Looks like its time for a dealership visit
Old: N55 E92 |
11-27-2014, 12:33 PM | #15 |
396
Rep 735
Hey, Which connector on the JB4 would it be? I took it to my mechanic at BMW who used to for LTMW and he changed the oil sensor and everything and said its possibly the tune causing it
Old: N55 E92 |
11-27-2014, 12:39 PM | #16 |
547
Rep 2,590
I have a procede and I think it was on the bigger left connector. I think the gray smaller subconnector. On the procede there is a three way connector that came loose on mine and made the sound you have.
11-27-2014, 01:07 PM | #18 |
396
Rep 735
Yeah I am going to take it off. Thank you
Old: N55 E92 |
01-11-2015, 08:40 PM | #19 |
396
Rep 735
Okay, So I took the JB4 and the car his been running fine for over 2 weeks now, No strange sounds, No low engine oil. Now what do I do? Should I try reinstalling the tune? I messaged Burger and they said the JB4 wouldnt cause that problem in the beginning
Old: N55 E92 |
