To beat the crap out of the transmission or buy a mechatronics
11-21-2014, 02:29 AM | #1 |
Rep 47
Hey guys this might sound stupid. But I've been dealing with so much issues lately with the transmission shifting rough, especially with jerky shifts everywhere. Just yesterday I had the DME, DSC, EGS programmed though ISTA from a local Indy. I'm about fed up with the way this car is shifting to the point that I am so tempted to just replace the mechatronics unit with a remanufactured one from theCTSC. However, who knows if that is the cure or maybe I just need a whole new transmission. Fluid has already been drain and filled, new filter pan, along with fluid level correction.
My warranty runs out in 4000 miles. I was told by my local reputable Indy to just beat the crap out of the transmission so I could get a replacement approved with my extended warranty. I'm not throwing any codes at all and without any codes, no warranty can be done. Should I take the advice from my local Indy and try to beat the life out of the transmission hoping it will set a code within the next 4000 miles or try to just replace the mechatronics out of my own pocket to fix these shifting issues. If you answer beat the crap out the transmission, how do you suggest I do so without making it look intentional. Thanks. |
11-21-2014, 10:24 AM | #3 | |
Rep 47
11-21-2014, 11:07 AM | #5 |
124
Rep 219
11-21-2014, 11:21 AM | #6 |
Fuck it dude, let's go bowling.
888
Rep 2,480
We're talking aftermarket warranty, correct? What are the terms? Do they really need a *code* to grant a claim? In other words, if the dealer determines the transmission needs work, don't they just file the claim to the provider? If this is the case, it just becomes a matter of convincing BMW that your transmission has a defect. And if that's the case, I'd take it to BMW NA since you've apparently been having trouble for some time. Of course, with all that coding work, you might have a difficult time making your case.
Or maybe I'm just misunderstanding the situation.
1M. Previously: '13 135is; '07 E90 335i; '02 325i; '99 Z3; '98 328is; '87 L6; '77 320i
11-21-2014, 02:33 PM | #7 | |
Rep 47
11-21-2014, 04:25 PM | #8 |
BMWCCA 149159
38
Rep 847
Changing the solenoids might work to help the quality of the shifting. Pretty clear you have cleared the adaptations which returns the transmission to learning mode. Good news is the solenoids are not killer to replace.
Love to hear what you decide to do... |
11-22-2014, 11:18 AM | #9 | |
Rep 47
I've read that the ZF transmission is pretty robust. Being that my car is stock, I don't know if the transmission will just break even if I try to gas it at every single green light. Being that I have 4000 miles left on warranty, the transmission might still be alive. Should have beat the crap out of it when I bought that car and had 24,000 miles on warranty lol. |
11-22-2014, 11:23 AM | #10 |
158
Rep 3,158
I would personally rather try to fix it. But that's how I usually think. "Better the devil you know", and all that.
Always do right. This will gratify some people and astonish the rest.
--Mark Twain |
11-22-2014, 12:45 PM | #11 | |
Rep 47
11-22-2014, 12:50 PM | #12 |
158
Rep 3,158
Man I'm not qualified to really answer that one; I drive a stick and am not really that knowledgeable on the inner workings of auto trannys.
--Mark Twain |
11-22-2014, 12:51 PM | #13 |
158
Rep 3,158
BUT.....one of the first things that people I've known around here do when they have shifting problems (more with manuals than autoboxes to be honest) is to replace the transmission fluid with a higher-performance alternative.
Don't know how hard that is or even how useful, but there, my $0.02.
--Mark Twain |
11-22-2014, 03:28 PM | #15 |
8
Rep 88
Yes, this is essentially how cash for clunkers cars were destroyed: http://jalopnik.com/5327580/video-ho...r-clunkers-car
I am not really suggesting you do this by the way. |
11-22-2014, 07:04 PM | #16 | |
Rep 47
11-22-2014, 08:41 PM | #17 |
28
Rep 121
Are you modded? It is a common problem that the Mechatronic adapter between the Mechtronic and transmission cracks and leads to erratic shifting problems. Usually the transmission itself does not break. This is DIYable. Taking it to a Euro trans specialist would definitely help.
http://www.thectsc.com/products/mech...p21-44-45.html |
11-22-2014, 09:05 PM | #18 |
109
Rep 1,062
Describe your rough shifting, imo these transmissions are crappy. Or maybe it's bmws software on them. Mine has been shifting rough for ages. Plenty of other people report the same.
11-24-2014, 12:57 AM | #19 | |
Rep 47
11-24-2014, 01:02 AM | #20 |
Rep 47
The rough shifts are intermittent. When the rough shifts occur, it's during the 1-2, 2-3 upshift under light to medium throttle in the 2000-3000 RPM range. A few times, the transmission seemed to clunk/slam into the next gear. The roughness doesn't feel very violent, in fact my girlfriend doesn't even notice when I point it out.
