11-20-2014, 06:59 AM | #1 |
110
Rep 219
Drives: MINI Cooper, 2020 X1
No media after flashing
Hi there,
after "successful" car flashing f22 MY2014 from i-level F020-14-03-503 (shipment) to F020-14-07-505 via ISTA-P 2.53.5 (the same result after return to F020-14-03-503 and flashing to F020-14-07-505 via E-SYS), MEDIA (HU-NBT) did not work. No track, no playlist, DVD drive did not work, USB did not work...But all rest in HU-NBT is works well. Navi, radio ... After flashing HU-NBT alone back to F020-14-03-503, all functions is back. The same problem with i-level F020-14-11-501 ( ISTA-P 2.54 and E-Sys 3.26.1-psdzdata 2.54). No faults in Rheingold 3.44 same Rheingold 3.45. Do somebody know what is the matter ?Aand if is it possible to flash euro spec. HU-NBT to higher i-level, than shipment at all ? Last edited by smahel; 11-23-2014 at 04:22 AM.. |
11-20-2014, 11:50 AM | #2 |
48
Rep 207
You either did the TAL calculation wrong, or maybe forgot to code after flashing?
If a region code isn't set on the DVD it wont play. PM me with your steps in E-SYS, and I can help you out. Did you flash the entire car? or just HU-NBT? |
11-20-2014, 02:12 PM | #3 |
110
Rep 219
Is not reason this ?
12-30-2014, 02:45 PM | #4 |
110
Rep 219
HU-NBT finally flashed
First of all I apologize for my English. Today I tried to flash my car using another computer (Win 8.1 64bit., psdzdata v 2.54.2, E-Sys 3.26.1, ENET). All steps exactly according to Shawnsheridans directions. All was O.K., no faults but NO MEDIA (HDD, DVD, USB) as usually. So I flashed HU-NBT alone back to shippment i-level ( psdzdata 2.52.5, E-Sys 3.24.2 ). Media was present, HDD, DVD USB - all is functional. Next step I tried - flashing HU-NBT alone again to i-level F020-14-11-502 but I checked ONLY blFlash and swDeploy ...BINGO media was functional still. But no cafd file and user manuals was present . So I used Shawnsheridans method of injecting to flash correct cafd and result -> media was still O.K. Next step was checking ibaDeploy alone and flashing, then coding my values for HU-NBT and miracle is here, My 253 is full on i-level F020-14-11-502 with all my coded values in FEM-Body, REM, KOMBI, ASD and HU-NBT. So I assume in next programming HU-NBT, flashing blFlash and swDeploy alone in the first step and then flashing rest - cdDeploy and ibaDeploy will solve this problem. Last edited by smahel; 12-31-2014 at 12:14 AM.. |
