E93 OBD socket broken
11-19-2014, 01:21 PM | #1 |
886
Rep 2,720
Hello friends,
Today my state inspection failed because the OBD socket is broken. Most probably BMW did it when I got the oil changed and they did some inspection on the car 6 months back. I searched a lot but didn't get any satisfactory answers. Can someone please tell me if its easily replaceable or I need to take out the side panel and replace the whole socket with wiring? Any battery disconnection required? I'm going to search on you-tube later tonight when I go home. Thanks for the help. Here are the pictures. |
11-19-2014, 05:34 PM | #3 |
Rep 20
The housing part number is 61136954580.
Removing the pins from the broken housing is a pain though, you need to either buy a tool to remove the pins, or make up one (I used 2 drywall knife blades ground down to fit inside the housing) Here is a posting showing removing the pins from the housing. http://www.bimmerboard.com/forums/posts/852232 You need to remove the side panel to get at the port. I'd unplug the battery just to be careful (I didn't and ended up blowing a fuse shorting some of the wires together by accident) |
11-19-2014, 06:52 PM | #5 | |
886
Rep 2,720
11-19-2014, 06:53 PM | #6 |
886
Rep 2,720
11-24-2014, 10:08 AM | #7 | |
886
Rep 2,720
11-24-2014, 10:09 AM | #8 |
886
Rep 2,720
