Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Drove into a puddle...
      11-18-2014, 06:19 PM   #1
BM91
Japan
76
Drives: 2012 Mercedes E550 Wagon
Ive been having the shittiest luck in regards to my car for the past few days.. On Friday some guy backed into my car while at a gas station and now this.. Last night I was picking up a friend from the airport, upon picking her up I had to go through this one lane one way tunnel/ramp which on the bottom consisted of a flood like puddle. I believe the puddle was as deep as where my foglights are since there is now moisture inside them. Without any choice I had to go through it. after going through the puddle I noticed an astronomical amount of steam coming out from my engine as well as exhaust when parking. I wasn't too worried since cars produce steam sometimes when they are running in a carwash but what worried me the most was when my car started idling roughly when parked.
The tachometer would fluctuate up and down multiple times as well as the car vibrating. I started and turned off the car a few times to hope that the issue would be go away but no bueno.. After picking up my friend and driving for 20 min and restarting the car again I noticed my car started fine once again but I am not 100% reassured. I went to my mechanic today and he scanned the car but there were no faults. Should I be worried that my car may have serious issues?
Im sorry for the long rambling.
      11-18-2014, 06:31 PM   #2
GetSomeE92
Drives: '09 Space Gray E92
You're most likely fine. Water probably just got into the exhaust system causing issues with too much back pressure. It likely cleared out as you drove the car and that is why the car is fine now.
335i Coupe, JB4 (G4, map 5) DCI and 40% E85 blend: 2009 BMW 335i Coupe: 12.173 @ 109.490 MPH
      11-18-2014, 06:36 PM   #3
uberbeast21
uberbeast21's Avatar
Drives: 2009 e92 335i
2009 BMW 335i  [0.00]
+1 this sounds about right
e92 335i l Cobb l VMR V710 l BMW PE l KW V1 l Cusco strut brace l M3 Control Arms l BMS DP's l
      11-18-2014, 06:39 PM   #4
Fundguy1
Fundguy1's Avatar
2032
Drives: 335 e93
Your fine. I went into a puddle once in a vetted. Hit debris under water, destroyed 2 tires and the distributer. That sucked.
      11-18-2014, 07:09 PM   #5
KeepRidingDirty
Professional Monkey Trainer
KeepRidingDirty's Avatar
65
Drives: 2007 BMW 335xi
Car sputtering could have also been caused by water getting on some car wiring. I wouldn't worry about it.
      11-18-2014, 07:21 PM   #6
Dark_Knight_335
Came to the N55 Darkside
Dark_Knight_335's Avatar
Drives: 2011 335 E93 M-Sport
If water gets in the manifold you can get a nasty case of water seize...IF it gets past the manifold.
      11-18-2014, 08:29 PM   #7
BM91
Japan
76
Thanks! Hopefully that's the culprit.
      11-18-2014, 08:34 PM   #8
JeM9
JeM9's Avatar
Drives: R.I.P. 11 328i AT
I hope it was worth it
If you started the car and drove it again without any irregular moments then you're fine.
      11-18-2014, 08:35 PM   #9
JeM9
JeM9's Avatar
I mean, I've had fun driving through huge water pools and splashing water all over the place. These cars are built to withstand weather conditions.
      11-18-2014, 08:47 PM   #10
drewnel22
drewnel22's Avatar
Drives: 2016 Subaru WRX
I don't see how this would even happen. It would have to get sucked up by the filters which it couldn't have from what the OP said.
      11-18-2014, 09:18 PM   #11
Dark_Knight_335
Got into a bunch of places when I got stuck in a flood in Newark a few years back with a 128 loaner...of course, that was a much deeper puddle...just about up to the doors. Oh, and I tried to start it up several times in that flood and eventually got it kicked over and out of it (stupidly enough), and the car gurgled like a motorboat for several minutes.
I was fortunate that 650 and change was all it cost me.
You're right, it seems not to be the case with OP.
      11-19-2014, 08:40 AM   #12
DF
239
Drives: F23
If you want to laugh I went through a deep puddle with the top down. The water soaked me and my interior :-)
      11-19-2014, 08:58 AM   #13
Fundguy1
Fundguy1's Avatar
2032
Drives: 335 e93
Newark sucks. I worked there for 5 yrs. flooded a bunch of times. Vette tragedy happened in Hoboken.
'08 e93 AW 335i 6MT,Vargas Stg 2+ 20T clipped,VRSF catless dps & 7"FMIC,ER chargepipe&Tial, MMP inlets&outlets,Motiv Stg 2 fuel rail&dual disc clutch/fly, JB4G5,MHD w/Motiv tune,Fuel-it Stg 3 LPFP,Wavetrac LSD w/lockdown, KwV2,M3(Strut brace,frt control arms,steering wheel)AKE blk sub bush,re11 245/305,19x8.5et30&19x11et43,SmartTop,RE trans mounts,Msport rear bump & skirts,15%tint,ZSP knob,Stoptech rotors,241k miles
      11-19-2014, 11:41 AM   #14
Dark_Knight_335
Ahhh! Small world man
