11-18-2014, 12:40 PM | #1 |
49
Rep 274
2 small chips on mirror
Hey guys I have two small chips on my passenger side mirror. Does anyone know an easy solution to fix them?
11-18-2014, 02:49 PM | #2 |
9
Rep 46
Finding replacement parts
Pretty hard to repair the shadowline trim. I haven't found any suitable repair ideas/solutions to date. Replacing the part is probably the way to go!
Sadly, I have similar damage and have been searching online for the replacement part - can't seem to locate in Shadowline Trim (High gloss Black). In the attached Mirror Parts diagram, it's referenced as a Supporting ring (#3). My local parts department hasn't gotten back to me yet, but my fingers are crossed it won't cost a fortune. If anyone can suggest an online source for the part I'd appreciate it. Good luck! |
11-19-2014, 01:57 PM | #3 |
9
Rep 46
Found the correct part numbers
If this is helpful, here are the correct part numbers for the replacement surround:
Left Mirror (Driver): 51-16-7-284-125 Right Mirror (Passenger): 51-16-7-284-126 |
11-19-2014, 02:47 PM | #4 | |
49
Rep 274
11-24-2014, 05:15 PM | #5 |
Rep 2
Touch up paint and use the Langka system. Similar to Dr Colorchip, however you built up the surface and then use a solvent to remove the 'blob'. Works well.
http://www.langka.com |
11-24-2014, 06:59 PM | #8 |
3074
Rep 5,577
I wouldn't.
Black is crazy to work with. On a piece down low near a front dam or sill - that's where I would use the Langka system of Dr. ColorChip before going to a more visible spot. |
Tags |
mirror chips |
