Theifs stole my windshield wipers! Ideas on securing them please
11-18-2014, 02:27 AM | #1 |
Swedish F31 lightenthusiast
48
Rep 496
Drives: BMW F31 320d xdrive Msport
So I came out this morning at 6AM to drive to work, My car is parked in a multi story carpark for residents and took off.I´d been driving for a while and decided to clean my windshield. Gladly, I did NOT decide to activate the washer, just hit the "one swipe" and was rewarded by an immense screeching sound as the metal tip slid along the windshield. Some asshat stole my drivers side windshield wiper! Luckily the local gasstation had the right one for my car (thank god BMW 3-series is a pretty common car in Sweden, or I would have been screwed, dealer opens at 9!)
Now I need two new caps, since said asshat took those aswell and some way to secure the windshield wipers. I´m thinking some form of wire or maybe a screw or something that could be hidden under the caps? Ideas?
//amullo
-17 F31 320d xdrive Msport -10 Ducati Multstrada 1200s |
11-18-2014, 02:59 AM | #4 | |
48
Rep 496
I´m not so sure.. I just want something more to atleast make it abit harder for them.
//amullo
11-18-2014, 03:21 AM | #5 |
94
Rep 1,100
Not truly answering your question but on the bright side at LEAST it was ONLY one wiper blade it could've been way worse
NOT Sponsored By Mommy Or Daddy
Build Thread 335i 1M http://www.e90post.com/forums/showthread.php?t=1090920 (SOLD) FBOs | MHD tune V5.1 stage 2| Alpina B3 Flash |
11-18-2014, 05:14 AM | #6 |
17315
Rep 18,737
You can secure them. Drill two small holes in the thin part of the wiper cover that sits over the arm where that first small square and the second longer rectangle cutouts are at the end of the wiper arm. Then use a small zip tie (wire tie) to secure the wiper cover to the arm by tying the cover to the arm with the wire tie routed through one hole then under the metal bridge between the square and rectangle cutouts then through the other hole drilled in the cover. Keep the "head" of the zip tie under the cover (back side of the cover for a clean look). Zip tying the covers to the arm will make the act of stealing the wipers a bit more difficult and maybe deter the next thief. The thief would need some wire snips to cut the wire tie. I doubt your average wiper thief carries wire cutters with him/her. Most thieves work at night so they'll not even see the zip tie and wonder, "WTF."
I came up with this approach to keep my wiper covers on when the plastic securing tab broke on one of them. Or you could go hard core and use a No. 6 screw. Drill a hole in the cover over the square cut out, then take a washer and grind it down square to fit in the recess of the arm, then secure it with a nut. Note: I suggest a No. 6 screw, which is probably a 4MM metric. Last edited by Efthreeoh; 11-18-2014 at 05:28 AM.. |
11-18-2014, 05:32 AM | #7 |
Save The Manuals!
64
Rep 491
But not the passenger side? Could it have been vandalism? At least your car wasn't keyed. That would have been more of a pain to get fixed.
I usually keep a spare wiper set in the trunk since wipers seem to fail in the rain at times when the dealer is closed.
2008 E91 36K, 6-speed, RWD, Alpine, Terra, Xenons, ZSP, ZCW, ZPP, PDC, CA, alarm, M shifter and M brake handle, Euro rear fog light switch, Euro aspheric mirrors, rear power outlets, Euro split armrest, Lidatek, remote V-1, Cocomats, beach sand, $10 clutch stop mod. 1998 Volvo V70T5 226K, 5-speed, original clutch (third clutch pedal!), aspheric driver's mirror, E-code headlights, IPD sway bar, strut tower brace & skidplate.
11-18-2014, 06:58 AM | #8 |
93
Rep 213
Drives: 2011 335i xDrive
Wire them up to your battery with a switch that comes on when you lock your car.
11-18-2014, 07:56 AM | #9 |
Is it the shoes!?
3884
Rep 5,112
11-18-2014, 11:57 AM | #10 |
1705
Rep 14,829
That's crazy. Due to them being included with free maintenance, I had never done them prior to Sat. And I had to watch a youtube to understand how to get those covers off.....
11-18-2014, 11:58 AM | #11 |
1705
Rep 14,829
11-18-2014, 12:14 PM | #12 |
Rep 17
Did you try applying a screw or something? That silver part on the last pic looks like you could secure it with some sort of ring on the other side. Maybe it suffices if something's not OEM and thiefs wouldn't bother investing more time in figuring it out.
11-18-2014, 12:50 PM | #13 |
48
Rep 496
Thanks guys. I like the ziptie idea. Ill start with that.
11-18-2014, 02:45 PM | #14 |
EXPAT
65
Rep 889
11-18-2014, 09:17 PM | #17 | |
851
Rep 2,793
11-18-2014, 09:21 PM | #18 |
Libertarian
132
Rep 1,577
Why not just take them off and throw them in your trunk when you park? There. Problem solved.
2011 335xi Coupe BSM (e92/N55/ZPP/ZCW, Alpina B3 Flash)
Bought 08/09/2013@53,340mi Current 3/13/2019@206,283mi Fail(s): tstat hous/water pump 89k, Chargepipe 106k, coolant tank 114k, FRM3 114k Maint: Walnut blast 101k, Trans/T-case Fluid 103k, OFHG 195k |
11-19-2014, 01:29 AM | #19 | ||
48
Rep 496
Yeah. This windshield wiper stuff made headlines, let me tell you! Quote:
//amullo
