1st boost logs w/ V2 and Forge DV's installed....94% and 96%
01-07-2008, 07:04 PM | #1 |
654
Rep 10,587
And it looks like I either still have a boost leak somewhere or my car simply is reacting differently to the V2.
The logs are MUCH smoother than before the DV holding steady boost around 12 - 12.5psi in 4th gear but I'm still dropping a bit in 3rd. This certainly does prove that my stock DV's were not up to the job so I'm really happy I got the Forge units. Now I need to figure out what else is going on. The only thing that I can think of is that my Helix Intercooler is causing lower psi either through a leak in the core or my connections are leaking. I purchased a T-bolt clamp this morning from a local turbo shop but it didnt fit, so I retightened w/ new worm clamps and went out testing. Here is the result......oh yeah, and this is the fastest my car has felt....feels great, can't wait for 15psi. 94% on 93 octane Bumped up to 96% to see if it would raise boost, didn't seem to make much difference but I didnt give it any time to adapt. I'll be back at 94% until I figure this out.
01-07-2008, 07:09 PM | #2 |
654
Rep 10,587
Just thinking about it, would my boost logs be that steady if I had a leak? I would think not right?
01-07-2008, 07:18 PM | #3 |
218
Rep 4,726
If it was a leak (enough to cause low boost) it would be rough. I forget now but did you try with stock map and bypass plugs? Did you have a gauge? It's weird for it to change if that was not the problem, unless the problem was related to the DV. (like the guy with the cracked vacuum line T)
01-07-2008, 07:19 PM | #4 | |
111
Rep 1,764
To find your leaks get a product call “Snoop” which is made by a several vendors. It is a soap type water based liquid but it work extremely well to find even the smallest leaks. It works 95% of the time with out taking anything apart as long as you can see the part. Orb |
01-07-2008, 07:22 PM | #5 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Definitely pressure test your induction system. Without confirmation that you don't have any leaks in the system (loose hose clamp, loose "T", leak in the aftermarket IC core, etc,.) it's hard to know the next step. Trying to compensate for a pressure leak somewhere by raising user TQ higher and higher is a big no-no.
Shiv |
01-07-2008, 07:26 PM | #6 | |
654
Rep 10,587
01-07-2008, 07:44 PM | #7 | |
54
Rep 1,677
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(e90post.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
01-07-2008, 08:20 PM | #8 |
74
Rep 1,271
Don't forget that you will see less boost with the cold weather (real cold weather like a NE winter). I would think the people in the Northern parts of the US will see significantly less boost than the folks in FL or CA even with a tune. Your boost seems pretty solid - just a bit low.
01-07-2008, 08:40 PM | #9 | |
654
Rep 10,587
It was in the low 70's here today, which is crazy warm for January, it was 9 degrees less than a week ago.
01-07-2008, 08:42 PM | #10 |
74
Rep 1,271
01-07-2008, 08:44 PM | #11 |
50
Rep 390
I thought I was the only one... my car seems to be doing something very similar... I had the cracked vacuum line which was causing my limp mode issues but now with that fixed I have still not seen 14-15psi. I have the spearco intercooler and was wondering if that would account for the drop as well. It seems that I can only hold about 12.5 psi average regardless of TQ settings.
01-07-2008, 08:44 PM | #12 |
54
Rep 1,677
Yea, Iam in the same boat, but it is high 70s to low 80s here in SFL .
01-07-2008, 08:48 PM | #13 | |
218
Rep 4,726
01-07-2008, 08:50 PM | #15 | |
654
Rep 10,587
Did you pressure test your intercooler?
01-07-2008, 08:55 PM | #16 |
50
Rep 390
I did, i lowered the intercooler so I could fit the adapter on the inlet side and tested everything from the intercooler forward... system held 25psi without any issues.
01-07-2008, 09:01 PM | #17 | |
654
Rep 10,587
I'm trying to figure a way to test the whole system at once so nothing is missed.
01-07-2008, 09:11 PM | #19 |
654
Rep 10,587
well the only thing to test there is your intercooler silicone couplings, just need to make sure they are good and tight I guess.
01-08-2008, 01:12 AM | #20 |
28
Rep 321
So SHIV is quick to blame me being at high alitude but i see many other people having the same problem. My boost is the same at 92%-98%. I think altitude has something to do with it but maybe there is another problem we all seeing The only difference i see when upping torque values is peek boost comes in earlier in the RPM range.
Altitude cant be restricting my turbos to only boosting 13 PSI even at this high altitude??? |
01-08-2008, 01:15 AM | #21 | |
50
Rep 390
Shiv, any suggestions on further trouble shooting or optimal place to pressurize the system to ensure there are no leaks? |
01-08-2008, 01:20 AM | #22 | |
218
Rep 4,726
Not saying that's the case in your instance, but I'll use any opportunity to bring it up because frankly it disgusts me.
