Is this the correct brake fluid level when cold?
11-18-2014, 08:50 AM | #3 |
124
Rep 219
cold or hot does not make any difference with brake fluid. Also, the max mark is for new pads. As the pads wear, the level drops which is normal. You should avoid topping off as pads wear. If you top off, then fluid must be removed when pads are replaced.
11-18-2014, 11:47 AM | #5 |
138
Rep 2,731
this is important to note.
11-18-2014, 12:12 PM | #6 |
26
Rep 109
11-18-2014, 12:18 PM | #7 |
138
Rep 2,731
correct. take out the excess with a turkey baster or some other method when you change the brake pads next.
otherwise when you push the pistons back into the calipers it will force fluid back up to the master cylinder and overflow. |
11-18-2014, 01:07 PM | #8 |
74
Rep 776
DANGER WILL ROBINSON!!!!!
just as a warning to you, brake fluid will eat right through paint, so be very careful!!!! and if you do spill some on your paint whatever you do DON'T wipe it off! spray it off with water. |
