Can anyone help identify this leak
11-17-2014, 07:30 PM | #1 |
Rep 28
I've been smelling some burning oil and found a crack in the valve cover so that got done this weekend but didn't solve the issue. Finally looked on the other side and OH WOW THERE's the leak! I've searched here and other places for comparison images but I can't find anything similar. Do you guys think this could be the OFH or is it the pan gasket? Oil is on top of the oil pan gasket and seems to run from the front all the way back. I'll drop the belly pan in a day or so to really look but I'd like to go ahead and order parts. I can see a bit of oil pooled down in the belly pan toward the back. Thanks for any help
[/IMG] |
11-17-2014, 07:42 PM | #2 |
19
Rep 260
My first thought would be the OFH. Did you clean it up and it reappeared? If not clean it up and see if it comes back. Check the OFH and see if you can see anything. Could have been the valve cover and just needed to be cleaned up.
