Paint of tail light?
11-17-2014, 06:48 PM | #3 |
Rep 284
Paint thinner? Not sure if that poses any risk to the plastic or not. Personally I'd reward the place that did it for their sloppy workmanship by letting them fix it.
11-17-2014, 06:51 PM | #4 |
551
Rep 2,293
I would bring it back to the shop that painted the rear bumper and have them removed
I ve read people removing paint with nail polish remover but if you apply too much you could damage it.... You could also sand it down with very fine sand paper ( 1500 or more) but again you could do more damage.... I used MEK to removed paint from my door frames and it worked wonders , I didnt even have to rub it too much but I wouldnt do it on my car unless it was a shitt y car... |
11-17-2014, 06:55 PM | #5 |
36
Rep 1,176
If it is just some overspray, you might be able to get it off with a clay bar.
335i Coupe, JB4 (G4, map 5) DCI and 40% E85 blend: 2009 BMW 335i Coupe: 12.173 @ 109.490 MPH
11-18-2014, 01:12 AM | #7 |
78
Rep 375
I'd say use a razor blade and just carefully chip away at it, depending on how much is actually on the tail light. If it's a lot, then go back to the body shop and bitch at them for doing such crappy work.
11-18-2014, 09:52 AM | #8 |
18
Rep 125
alcohol? gas?
2009 e90 mtec| alpine white|black interior| DC intake| gloss black kidney grills| LED Interior| LED Exterior| gloss black vinyl roof| BBS RS-GT wheels| 235/35/19 front| 265/30/19 rear| KW V1 coilovers|CF trunk spoiler| CF diffuser| HKS catback exhaust| Fully coded| |
11-18-2014, 10:03 AM | #9 |
1103
Rep 7,063
Gasoline. My YouTube channel I have a video up on how to do it. Make sure you tape down your painted surfaces and use a sealant on the tail light once removed.
E90 Build Thread (SOLD) http://www.e90post.com/forums/showthread.php?t=809436
F15 Build Thread (SOLD) http://f15.bimmerpost.com/forums/sho....php?t=1064084 |
11-18-2014, 10:32 PM | #11 | |
Rep 284
By the way, OP, any shop worth their salt should have removed the lights from the trunk lid before painting it, IMO. Only takes a minute and then there'd be no risk of leaving an exposed edge in the new paint that could start flaking off later. |
11-20-2014, 11:09 AM | #12 |
136
Rep 523
I'm really disappointed the shop I took it too did an incredible job matching the color and they come HIGHLY recommend in the area. I know people that have used them before and had great results and it's where the local BMW dealer sends all their cars. I ended up having it painted twice because the first time left a mark on the deck lid and now I don't quite like the results either because there are spots that you can tell it was painted. A few lines by one of the lights and where they taped off by the lights above the license plate you can tell if you look underneath. I don't want it re done again because I can live with this and I fear they'll only mess up something else. Live and learn I guess, I thought I made a good choice they got rave reviews by friends and online also 5 star by tons of people and the only cars there are late model Germans. I guess you just never know /:
As for the paint on the light it's not even enough to scrape off it's very light and transparent about the side of a penny. Tried nail polish removed didn't work. Maybe compound/clay bar/ gasoline? Thats what I'm hearing? I don't wanna go back to the shop, they did enough damage in my opinion. |
11-20-2014, 11:23 AM | #13 | |
30
Rep 1,093
11-20-2014, 11:33 AM | #16 |
142
Rep 726
clay bar, gas, thinner,
2006 Bmw 325xi VMR V715/OE lip/Redlines/Zsp Springs
1999 Eclipse Spyder Gst 16g/264cams/550cc/255lph/corbeau seats/Comp Stage 4 Clutch/ECUflash etc... |
11-20-2014, 12:55 PM | #17 |
57
Rep 1,038
Definitely start with mechanical removal (scrape and/or rubbing compounds). Then proceed to solvents. And finally finish it off with fine plastic polish.
With solvents acetone is the best, but it can haze some plastics. Test your taillight lens in an inconspicuous area for acetone resistance (this applies to all solvents, actually). Acetone is safe on fully cured car paint and clearcoat, but it might haze fresh coats. Since you just had it painted, you have to remember that. (In any case, acetone "stains" are easily fixable with polish.) Last edited by AndreyT; 11-20-2014 at 08:06 PM.. |
11-20-2014, 02:40 PM | #18 |
583
Rep 2,233
Drives: '12 M3
What shop did you take it to?
