cold start stuttering and rough idle for 5mins then car is fine n54! help!!
11-17-2014, 02:35 AM | #1 |
16
Rep 271
As per the title above.. what may causing this? Only codes i get is the water pump. Can water pump cause this action? Only happens on cold start.
bmw 335i e92 n54 2007 AT running fbo
_______________________________________\\\ BMW 335I E92 2007 RHD 6AT,HYBRID TURBOS,BMS ADAPTER W/ 3.5BAR TMAP,VTT INLETS,JB4 G5ISO W/ MHD FLASH,AEM METH KIT W/ FSB,BMS DCI,ER CHARGEPIPE & TIAL BOV,VRSF C@TLESS DPS,FMIC,BMS OCC,BMS CABIN FILTER,MUFFLER CUSTOM BULLET,97RON PUMP GAS Last edited by erwan35; 11-17-2014 at 03:00 AM.. |
11-17-2014, 06:43 AM | #2 |
16
Rep 271
Im going to replace my water pump if so. But what if its not? Ive changed my thermostat already and now the only code is failing water pum. Please anyone help
_______________________________________\\\ BMW 335I E92 2007 RHD 6AT,HYBRID TURBOS,BMS ADAPTER W/ 3.5BAR TMAP,VTT INLETS,JB4 G5ISO W/ MHD FLASH,AEM METH KIT W/ FSB,BMS DCI,ER CHARGEPIPE & TIAL BOV,VRSF C@TLESS DPS,FMIC,BMS OCC,BMS CABIN FILTER,MUFFLER CUSTOM BULLET,97RON PUMP GAS |
11-17-2014, 07:38 AM | #3 |
40
Rep 669
If the waterpump is giving you a code, I would replace that regardless.
I had cold start stuttering that would go away after about 30-1 min. Eventually a code for missfire on cylinder 6 showed up. Changed sparks, plugs, and the injector. Code went away. but rough idle was still there. Cleaned up the intake valves (walnut blast) and now its smooth. If you get no codes, and you havent done any of the above, consider start doing them. Sparks and plugs are easy to diy. |
11-17-2014, 10:13 AM | #4 |
16
Rep 271
Ok. But my spark plugs are few months old because i just changed them. My milage is 102k km. And i just had bms occ installed. But i have not yet clean the intake valve.
11-17-2014, 01:20 PM | #6 |
Professional Monkey Trainer
65
Rep 423
I would say these items are unrelated. if water pump codes its on it way out, replace it before it leaves you stranded. Rough idle is injectors 99% of the time. They leak when sitting for an extended amount of time, which is why it runs rough when started. When the excess fuel that the injectors leak has been burned off the car will run smooth again.
11-17-2014, 03:51 PM | #7 |
16
Rep 271
Ok thank you and noted!!
11-17-2014, 08:12 PM | #8 |
52
Rep 278
Yepp. Most likely leaky injectors, or carbon build up. If your car is due for them, I'd do an entire overhaul with injectors, coils, and not plugs if you just replaced them. Ecs has a good maintenance kit.
11-18-2014, 06:58 AM | #10 |
what's for lunch?
Rep 61
+1 on injectors, mine was doing the same before i replaced them. you can check by pulling spark plugs after a cold start. the bad ones will be wet with fuel
l st v1 coilovers l dinan fixed camber plates l cobb v3 l afe dci l vrsf 5" stepped ic l vrsf catless dp's l vrsf cp l tial bov l esm-004 l
11-18-2014, 03:22 PM | #11 | |
162
Rep 689
First time I've read an explanation behind this issue. Thank you! .. and I probably need injectors soon.
Nick | 2011 Competition Package M3 Sedan | @Restoration_Motorsport on IG
11-26-2014, 09:47 AM | #12 |
ahat
1036
Rep 2,592
Come on in, the water is a bit chilly but the alternative sux.
'13 335IS N54 (1 of 373 LeMans Blue out of 3597 total production e92)- Grey interior (1 of 24 in LMB with any trans- 1 of 14 with DCT)-MODS -MFactory LSD/MHD-BQ custom Tune/ATM-IC/AFE Momentum GT Intake/Konis/Mfront&HeimJoint Rear rods&arms/Brembos. https://photos.app.goo.gl/Lo6aHZRo7XqtPkhL8 |
11-26-2014, 02:43 PM | #13 |
The Wolf
247
Rep 987
Drives: stuff
same thing mine did, injectors.
-2019 BMW m850i convertible
-2021 Dodge Charger Hellcat Redeye Widebody |
