New 335i - Only one exhaust active
01-07-2008, 03:44 PM | #1 |
Rep 21
Collected my new 335i on the weekend. I have found after 100 miles that only one exhaust is working. The one on the right (UK car) is working which can be seen (soot) and felt (hot air). The one on the left is soot-free and no hot air is felt. Has someone shoved a banana up one pipe? Even after revving, there is no change.
01-07-2008, 03:46 PM | #2 |
33
Rep 934
Their is a valve in there that controls the exhaust. The one on the right is open all the time and the one on the left opens as needed.
2007 e85
Imola Red | Black Leather | Carbon Leather Trim | Premium | Navigation | Heated Seats |
01-07-2008, 03:50 PM | #3 |
Rep 64
When I start my car in the cold, about 35 degrees, I notice for the first 3minutes only right exhaust works. After about 3 minutes, the car makes a different sound, I see both exhaust working. (I can see white smoke coming out from both exhaust because it's cold)
01-07-2008, 03:55 PM | #5 |
Rep 337
Search for "golf tee mod" if you want both sides always operational and more noise.
E90 335i: TiAg, black leather, burl walnut, 6MT, Sport, Premium, Cold Weather, PDC, Sirius, Comfort Access, Nav
ED: 3/30/2007 Redelivered! 5/15/2007. |
01-07-2008, 03:57 PM | #6 |
'07 E92 335i SOLD
21
Rep 452
This has been discussed several times in the past. It is normal. If you want, there are a few ways to deactivate the valve so both sides are flowing all the time. Either with the "golf tee mod" or in the trunk on the driver's side, there is a small panel you can remove behind the tail light, revealing a sensor you can disconnect to keep the valve open at all times.
01-07-2008, 04:00 PM | #7 |
313
Rep 8,050
Drives: E92 M3
i just knew that
01-07-2008, 04:29 PM | #8 |
Bad Lieutenant
232
Rep 3,517
MODS: Can we put a sticky regarding the valve that controls the exhaust system, maybe with links to the golf tee mod(s)? Thanks.
02 E39M5 | TiAg/Schwartz | Tubi Rumore | Ultimate Ti Pedals | E60 SSK | Jim Blanton 3.45 40/100% | Coby Alcantara | StrongStrut STB
01-07-2008, 04:30 PM | #9 |
Smiling politely
165
Rep 7,931
Hell, we had a new thread on this started just a few days ago: http://www.e90post.com/forums/showthread.php?t=105206
Interestingly enough, the 330i has a similar valve in its right exhaust, so only the left side exhaust works until it is warmed up. The 325i did not have this exhaust valve, IIRC. Does the 328i?
E90 330i Black Sapphire 6MT | 991.1 C4 Platinum Silver 7MT
01-07-2008, 04:38 PM | #10 |
142
Rep 3,161
http://www.e90post.com/forums/showth...light=golf+tee
If you read the thread above, that will answer all your questions. I just did the golf tee mod this weekend and it sounds louder, especially on a cold start. Great cheap mod!!! |
