Engine light - P014A and now P0160
11-16-2014, 12:08 PM | #1 |
14
Rep 208
Hi Guys,
I scanned my car and got a P014A code reading "02 sensor delayed response - rich to lean" I cleared the code and it has gone away. I will see if it stays off when i take it for a drive. The car drives the same and doesn't feel any different. thanks in advance *UPDATE* drove over 200KM and warning light is still off? am i safe?
2008 E90 328 X-drive -KW V1- Auto-Sport-Blacklines-LED interior lighting
Summer: Style 195 F-225/40/18 R-255/35/18 on Bridgestone RE760 Sport Winter: Style 161 - Sottozero RFT 225/45/17 square Last edited by petelazro; 11-17-2014 at 06:09 PM.. |
11-17-2014, 10:08 AM | #2 |
14
Rep 208
BUMP?
Summer: Style 195 F-225/40/18 R-255/35/18 on Bridgestone RE760 Sport Winter: Style 161 - Sottozero RFT 225/45/17 square |
11-17-2014, 11:07 AM | #3 |
19
Rep 595
Unless you have an exhaust leak, or maybe even an extreme vacuum leak, then you may need a new set of O2 sensors. Don't worry, if there's a problem the code will come back.
11-17-2014, 06:07 PM | #4 |
14
Rep 208
thanks.. today the CEL came back on and i scanned it and got p0160 code
so initially p014a - ( the program said "o2 sensor delayed response- Rich to lean-Bank 2 Sensor 2) and now p0160 - 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)(the program said "no activity" i assume its the sensor itself and not an exhaust leak since there is no activity detected. also can i get away without changing it for a while since its a post cat sensor?
11-17-2014, 06:33 PM | #5 |
19
Rep 595
I would check to see if the sensor is plugged in fully, and that the wiring is well insulated. If that isn't it you are looking at replacement, but O2 sensor failure isn't common.
