Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Car shakes and loses power when OT
      11-15-2014, 06:24 PM   #1
sharks25
Drives: 2007 335i
Hey guys,
I'm a little freaked out. My car (335) freaks out whenever I step on it hard. It seems to seize up and sputter then the service engine soon light comes on and my rpm meter sort of quivers whenever I touch the accelerator. It's happened twice, both times the car has kept driving (I just let it coast and tried to touch the accelerator as little as possible) and both times the light has gone away shortly after and things go back to normal.
Any idea on what's wrong?
Thanks!
      11-15-2014, 06:42 PM   #2
bob.g
21
Drives: 2006 325xi
it's usually coils or spark plugs..probably coils. It's a common issue dont worry about it.
coils are about 40$ each, once one fails you might as well do them all. You can do the work yourself it isn't very hard.
      11-15-2014, 06:51 PM   #3
335NJ
Drives: 2008 335i 6MT E90
Read codes. Read the sticky for misfires, sounds like exactly what you're issue is.
How many miles on plugs?
      11-15-2014, 06:54 PM   #4
bob.g
21
Drives: 2006 325xi
on a sidenote i recommend the bmwhat app with an elm327 obd code scanner (on ebay), so you can easily diagnose issues with your car and code stuff..should set you back 65$ in all.
      11-15-2014, 06:54 PM   #5
NGEE
Fuck it dude, let's go bowling.
NGEE's Avatar
888
Drives: 1M
Codes
1M. Previously: '13 135is; '07 E90 335i; '02 325i; '99 Z3; '98 328is; '87 L6; '77 320i
      11-15-2014, 07:31 PM   #6
sharks25
Drives: 2007 335i
I'm gonna take it in to someone with a code reader before driving it more, I was just wondering it any of you guys had a similar problem so id know what to expect.
Thanks for the help guys
      11-23-2014, 12:51 AM   #7
painoz
Drives: 2007 335i, 2013 M5
Misfire. Just had the same thing exactly happen to mine. Misfire #4. Just had car walnut blasted and moved coil on 4 to number one. If one misfires I know it's a bad coil.
      11-23-2014, 01:10 AM   #8
oneup335
114
Drives: Stock
that happened to mine and dealer said it was injectors and replaced it under my warranty
      11-23-2014, 02:16 AM   #9
Dark_Knight_335
Came to the N55 Darkside
Dark_Knight_335's Avatar
Drives: 2011 335 E93 M-Sport
2007 N54...yep, all this sounds about right.
I'm guessing the car has over 60,000 miles on it too, so I'd get a walnut blasting done too if I were you while you're at it -good luck sir.
      11-23-2014, 02:30 AM   #10
E92ML
E92ML's Avatar
Drives: E92 2008 335xi Coupe
I had the same problem when OT. It was my spark plugs. I got them replaced and car ran perfect again
Performance: JB4 ECU, CP-E DP's, WW BMS Meth Kit, AR meth elbow, BMS DCI, AFE Intake Scoops,
Exterior: Enkruez 19" H8R, H&R Spacers, Aero Lip, Tint, ACS Roof Spoiler, HID AE's, HID Fogs, Black Grills, Sport Pedals
      11-23-2014, 06:49 AM   #11
Miller335
291
Drives: 2007 E92
This is coming from someone who created a thread about trolling on this forum right?
2007 E92 335 6MT w/335is clutch FBO MHD E60 Wedge map 49k miles
      11-23-2014, 07:18 AM   #12
blown07
blown07's Avatar
202
Drives: 335i
Had my first misfire under WOT and the code showed multiple misfire on cyl 6 only. The misfire would continue until I shut the car off and restarted. I figured it was a coil or injector as a plug should come back on line out of boost. Ordered 2 coils ( 1 spare ) and it fixed it.
Don't plan on replacing all of them unless it becomes an epedemic. Do most guys do all of them? Car has 140kkm but not sure if they are all original.
335i FBO,Meth,JB4,Sutphin flash,LSD,GCLites 11.25@127.4 on NT05R
335xi FBO,Meth,JB4,Sutphin flash,VTT stage1 11.38 1/4 - 7.30 1/8th - 3.35 0 to 60 @ 0C
      11-23-2014, 07:36 AM   #13
NGEE
NGEE's Avatar
888
Drives: 1M
I can only relate my experience, which is that they failed one after the other. Replace one...two months later another went. Replaced that....three months later... etc. I finally just replaced all the remaining ones. I had the dealer do it, but if I had to do it over I suppose I'd do what you're doing - always keep a spare on hand, and when I use the spare, replace it.
      11-23-2014, 11:20 AM   #14
Karbon
Karbon's Avatar
Drives: 2010 335i
Spark plugs!
Replace all of your plugs and test it out. 90% of the time it's just in need of new plugs.
If that doesn't work, then do coil packs.
(SOLD)2010 Alpine White 335i - Sports Package, Premium Package, Navigation, Comfort Access
2016 Infiniti 3.0t Q50S
      11-23-2014, 11:26 AM   #15
Dark_Knight_335
Wasn't being sarcastic sir, was being truthful.
It sounds like those issues would happen with an 07- I don't see where that's a problem. Hundreds of threads can't be wrong
      11-23-2014, 01:53 PM   #16
Johnny Boost
324
Drives: '21 M850i GC
Pretty normal for any tuned engines, even N55s. The spark plugs will fail prematurely.
WedgePerformance E40 MHD | Performance Exhaust Mod | BMS DP | Vibrant 1790 | BMS Intake | VRSF CP | xHP Stage 3
Michelin PSS | M3 Control Arms
LUX v4 LEDs | Shadowline Grills | Lip Spoiler
      11-23-2014, 02:23 PM   #17
NGEE
NGEE's Avatar
888
Drives: 1M
DN - I think Miller was implying that your response didn't address the OP's question, and therefore wasn't helpful. Dunno?
e.g.:
Question: "My car is having this problem, any idea what it might be?"
Answer: "Your car is an '07."
OP might not know what that means, specifically.
      11-23-2014, 02:33 PM   #18
Dark_Knight_335
I guess with burns my ass the most is Miller didn't fully quote my reply, during which I clearly said some things that further supported my claim of it being a 2007- only implying it was an older car and probably in need of several of the suggestions that several of you posted ("all this sounds about right" was meant to mean everything everyone posted in response sound like valid things to check.)
I didn't just say it was a 2007 to be an asshole, and I even suggested a walnut blasting if it was a higher mileage 335 to further try to help, and also said good luck, but whatever...
Taking people's statements out of context and just using what you think works to make somebody out to be a dick is kinda shitty...just saying.
      11-23-2014, 02:46 PM   #19
NGEE
NGEE's Avatar
888
Drives: 1M
haha - even I read your post as: "OP, everything that you are saying is wrong with your car sounds just about right, given it's a 2007."
Human words. So confusing Peace out.
      11-23-2014, 02:48 PM   #20
Dark_Knight_335
Yeah I get it now bro... well at least I explained myself a little further and hopefully everyone understands that I wasn't trying to bust balls or be a "troll"
