Spec Stage 3+ owners in here
11-14-2014, 01:51 PM | #1 |
Fastest 335 on Earth
39
Rep 426
Just got my Spec Stage 3+ clutch installed with their lightweight single mass flywheel.
Questions I hear a lot of grinding and chatter INSIDE the car at low RPMS, it goes away when clutch is down. Seems to be normal I think? Never had a clutch sound like this before so I can't say for a fact. It does not seems smooth...mind you there's only 60 miles on the clutch. Am I just freaking out? Is everything ok? Thanks!
E92 335i, 6MT- YouWish Single turbo, Precision 6466, Doc Race intake manifold w/port injection, Precision Raceworks coil packs and Stage 3 lpfp, 3.46 geared Mfactory LSD, VRSF 3.5" single exhaust, Toyo R888Rs, Spec Stage 3+ clutch, DSS axles, RTD shifter, Motiv, boost box and flex fuel, WOTBOX, MOTIV tuned...and much more
11-14-2014, 02:02 PM | #2 |
39
Rep 227
Normal. The single mass will induce a lot of gearbox rattle. The clutch will be noisy at low rpms also. I went through the same thing with my 2+. I put the uuc fluid cocktail in the tranny and the gearbox rattle is gone other than when the a/c is on. Even then it's greatly reduced.
11-14-2014, 02:09 PM | #3 |
533
Rep 2,872
From what I've read, that setup will be loud/chatter. Also, the clutch should smooth out engagement as it breaks in a bit. Drive often and try to rack some miles on it.
11-14-2014, 02:16 PM | #4 |
34
Rep 783
Just life with a single mass flywheel. It is completely normal.
'07 335i E90 - PTF ProTUNED by Dzenno - COBB FMIC - AFE DCI - AA DPs - HFS4 Meth
'09 M3 - Stock |
11-14-2014, 02:25 PM | #5 |
39
Rep 426
Alrighty then, Thanks
11-14-2014, 02:40 PM | #7 |
39
Rep 426
I went with the steel one
