11-13-2014, 03:06 PM | #1 |
Rep 15
Winter Car Washing
Apologize if this is on the site - couldn't find via search.
Anyone have suggestions for washing the car during the winter? Is the best worst option a touchless car wash and no towel dry? Thanks |
11-13-2014, 10:54 PM | #2 |
IG@i.am.wah
2779
Rep 3,815
Drives: M2 CS
I just go to those self serve pressure washer places and just accept that in the winter the car won't be perfectly clean.
11-16-2014, 08:53 PM | #6 |
69
Rep 127
I would use a do it yourself car wash with the high pressure nozzle. I bring two five gallon buckets close to full with hot water. I put in my car soap into the buckets after they are filled and put the lids on. I use the first cycle to suds up the water and rinse the car as well as possible just using the rinse setting. I then wash the car with the two buckets using a microfiber mitt. After use another cycle to rinse off the car. I then use a water blade to get off most of the water and work quickly to dry it off with microfiber towels. I will dry the door jambs and trunk area to get any residual water and debris off. I bring my other chemicals if I need to clean the interior with. Then I can throw all the towels and mitts into the now empty buckets to transport home. This works best if you go early morning or late night when you will have more time since I can take an hour or more. Some may say this is too much work but why be lazy on the BMW. In that case just buy a Chevy and never wash the damn thing!
11-16-2014, 09:06 PM | #7 | |
37
Rep 106
2019 G07 X7 4.0 - Black Sapphire
2015 F80 M3 - Sakhir Orange / BLK (RETIRED) 2012 E92 M3 - Interlagos Blue / BLK (RETIRED) 2008 E60 528i - Space Grey / BLK (RETIRED) |
11-17-2014, 09:41 AM | #8 |
Rep 24
11-17-2014, 08:35 PM | #9 | |
37
Rep 106
11-18-2014, 08:59 AM | #10 |
Rep 24
It can certainly be used outside, and even in the sun.
I just think garage/winter because of the elements... It's currently 9 degrees with a windchill of -12 outside (and a balmy 50 in my garage). |
11-18-2014, 11:42 AM | #11 | |
28
Rep 118
You can certainly use it outside, but the point is to stay warm in the winter so you DON"T HAVE TO go outside. LOL anyways, I use a liberal amount of this stuff (1.5oz per 2 gallon), just to make sure I don't end up with scratches. There's a WAX and SHINE version, that's the stuff I use. Love it. I also use the 2 bucket wash method, make sure to rinse the mitt in clean water before dip it back to the soup bucket. If you wash your car frequently, you should be fine. I have opticoat on my car and this ONR + Opticoat = 20 min wash. wheels = another 20 mins. so you can get everything done in 40 mins. |
11-18-2014, 01:24 PM | #12 | ||
37
Rep 106
11-18-2014, 01:43 PM | #13 |
1792
Rep 2,995
My only comment on Optimum No Rinse or similar...
You want to SOAK SALT ENCRUSTED AREAS thoroughly before wiping the crust off. When dealing with that heavily soiled areas, take lots of time, use more water/soap than expected, and do small small sections before rinsing the mitt out. ONR is an excellent option for winter time cleaning - but you will drag salt across your paint if you aren't very careful. |
11-18-2014, 02:43 PM | #14 |
211
Rep 289
An area many don't give consideration is protecting their bodies during the cold weather detailing sessions. For some great tips, read this piece from Detailed Image: http://www.detailedimage.com/Ask-a-P...-on-your-body/
11-18-2014, 09:29 PM | #15 | ||
37
Rep 106
11-19-2014, 07:41 AM | #16 |
386
Rep 2,988
11-19-2014, 07:43 AM | #17 | |
386
Rep 2,988
11-19-2014, 01:33 PM | #18 |
127
Rep 302
I was thinking about touch less car wash like 2-3x a week and autoglym aqua wax every 2 weeks, as it gets extremely cold here and would be really difficult to stand outside. What do you guys think?
11-21-2014, 11:03 AM | #20 | |
Rep 71
Great article.
11-21-2014, 11:09 AM | #21 |
Rep 71
I was in the touch-less car wash camp for years. This past summer I did a total insulation project on my garage to include putting in a new garage door with the most insulation/UV available. The temps are currently in the mid 20's and the garage during the daytime is tending to be in the mid to upper 40's. A big improvement over what it was last winter. I do have the Race Deck Flooring also and I'm sure that not having to stand on concrete is a help also. This winter I'm hoping to skip the touch less car washes and do more inside.
11-23-2014, 11:16 AM | #22 | ||
30
Rep 253
2015 BMW ///M3 6MT: MW, 19" black wheels, extended leather
Mods: IND back grill, 25% 3M Tint, XPEL Ultimate, V1 concealed display setup, Bavsound S1, K&N+charcoal delete |
