Catless downpipes e90
11-12-2014, 08:27 PM | #1 |
Rep 33
Ok, I just got new 3.5" ss tips put on, a resonator delete and the secondary cats replaced with an x-pipe. The tips look great and the sound is awesome so far. It is definitely deeper and has a nice growl to it.
My next plan was to get VRSF catless dps put on so I can go to stage 2. Before I left, the muffler shop recommended that I have them make downpipes for my car instead of buying aftermarket ones. Questions: 1. What is the size of the oem downpipes? I know VRSFs are 3" and wasn't sure if that was the same as oem or .5" bigger. 2. Could they just cut the primary cats out, straight pipe it and that work for stage 2? 3. I would probably save around $100-200 if they did all of the work. With that being said would you have custom downpipes made or just buy from VRSF? I'll try to get a video of the sound up tomorrow! |
11-12-2014, 09:12 PM | #2 | |
533
Rep 2,872
I'd get VRSF and call it a day, they'll bolt right up, and will outlast the car i'm sure. Plus they've been proven by many.
BSM E90 6MT-JB4 G5 ISO-BMS DCI-Golf-Tee Mod-Hankook S1N2 Non-RFT-ER Chargepipe/TiAL BOV-E40 blend-VRSF V2's-M3 CDV-MHD/JB4 FLASH-VRSF 5" STEPPED FMIC
11-12-2014, 09:28 PM | #3 |
2095
Rep 43,350
I don't mean to sound pessimistic but there's now way they can make you 3.5" dp's that will offer the same fit and dimensions for anywhere less than what we sell them for. I absolutely believe they can make a catback cheaper than most offerings available but their downpipes won't be mandrel bent, 3", 304 grade stainless steel or have the same CNC flanges. It's simply not something anyone can do cost effectively in a one off situation.
11-12-2014, 09:56 PM | #4 |
79
Rep 259
You can't go wrong with the VRSF cat-less downpipes. The quality of the pipes and welds are out of this world for the price they are selling them for. I installed these myself and all I can say is that everything lines up perfectly in the right place for an easy installation. VRSF makes some killer products for great prices!
11-12-2014, 10:21 PM | #5 |
BimmerPost Supporting Vendor
24199
Rep 190,807
Just get a proven DP, your first choice VRSF DP is a very good one
11-12-2014, 10:51 PM | #7 |
Rep 33
That's what I was thinking. Looks like I will be ordering the down pipes and fmic from Tiago in the next week or two. Can't wait to hear the difference in sound it will make! Stage 2+ won't be bad either
11-12-2014, 10:52 PM | #8 | |
Rep 33
11-12-2014, 11:02 PM | #10 |
Buy a 335 they said... It'll be fun they said...
117
Rep 995
Drives: 2007 E92 335i
For the rest of us it can take up to 4 days, one or two broken O2 sensors after you break some perfectly good ones, a complete disassembly of the steering column, a new clock spring for the steering wheel controls when you break the current one and... a lot of swear words.
If you don't have a lift, you'll also feel like you've been gang bashed for the following week as you recover from all the cuts, bruises and sprains in all of your limbs. Get down pipes they said. It'll be fun they said. |
11-12-2014, 11:06 PM | #11 |
79
Rep 259
It took me around 5 hours, I had no lift, I just put the front wheels on ramps. The best thing to do first underneath the car before you start the installation is to drop the steering rack. This gives you a lot more space to access the turbos. It is literally held on by 2 bolts.
11-13-2014, 07:31 AM | #12 |
261
Rep 1,093
The only thing the shop can do for you cheaper is gut the factory cats. Size is not the issue, the restrictive cats are. There are/were several dyno's around the forum proving this.
11-13-2014, 08:43 AM | #13 | |
Rep 33
