The Tire Rack
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Battery drain issue
      11-12-2014, 06:55 PM   #1
NightStalker
NightStalker's Avatar
267
Drives: Audi
Exclamation Battery drain issue
Replaced my old battery with similar specs all coded. few days ago my car was completely dead.
had it charged and checked.
turns out the battery is fine but can't seem to find the culprit as in what keeps draining it.
one thing i have noticed is that after the car sleeps (transmission light turns off) the car makes this fuel pump noise and then the "start stop push button" lights up....and sometimes it stays lit up for a while...maybe that can be my problem but has anyone had something similar to this?
recent electronics mods are the high performance interior led light. had it installed few weeks ago so idk
      11-12-2014, 07:52 PM   #2
NightStalker
267
Drives: Audi
UPDATE had this code pop up few days prior
Possible causes
- Faulty Fuel Level Sensor
- Fuel Level Sensor harness is open or shorted
- Fuel Level Sensor circuit poor electrical connection
Read more: http://engine-codes.com/p1408_bmw.html#ixzz3IuRNIW00
maybe this is why my car does not goto sleep
      11-12-2014, 08:06 PM   #3
BashShah
296
Drives: 2012 335i Sedan
My car is a 2007 335i sedan.
Built date: sept 2006.
Daeos vista harness installed.
A few nights ago, after parking at home noticed fuel pumping every 9 sec.
On/off.
Traced it to my harness not making good contact to my left AEs.
A short will cause your fuel pump to cycle on/off repeatedly.
So if you have a short code....investigate it fully to rule it out.
DN
      11-12-2014, 08:17 PM   #4
NightStalker
267
Drives: Audi
On/off.
DN
i see, i think it may very well be one of my faulty fuel sensors..thats causing a short
Tags
battery, dead, drain
