Rear tires middle section wearing faster
11-12-2014, 06:00 PM | #1 |
30
Rep 285
I have the Michelin PS A/S 3 tires front and back. Excellent tires.
Here is the problem... In the rears, middle section of tire treads are wearing out much faster, while outer side is maybe twice thicker....now you might think I "overinflated" the tires, right? NO! It's 255x3518s wrapping around VMR VB3 wheels. So I had it up to 38psi before and over time I checked and I see middle area gradually wearing faster, so I deflated to 34psi. But it seems to make little difference. I have OFT and I get on it sometimes but this problem in the middle is concerning me. Low tire pressure means bad MPG. Anyone? Last edited by 2fast4; 11-12-2014 at 06:09 PM.. Reason: added some more |
11-12-2014, 06:47 PM | #3 |
319
Rep 1,023
What size are the wheels? Maybe improperly sized tire for the rim?
Also, once you have uneven wear, fixing your tire pressures won't fix it. Now you will wear properly, and everything will wear at the same rate, so you'll still have the middle more worn.
2001 e36/7 M Roadster 5spd
2008 e90 335i 6spd 2011 e90 335xi 6spd 2011 e70 x5 diesel 2010 Ducati Monster 696 Last edited by jwalker87; 11-12-2014 at 07:01 PM.. |
11-12-2014, 07:44 PM | #6 | |
30
Rep 285
Are you suggesting that 38psi is too high for it? The manual says 42psi for up to 100mph, or 36psi for over 100mph. So I'm way below the speed. I emailed the VMR for pressure info and the jerks never replied to me. Thanks for the the fact that I'm stuck with uneven wear now. No amount of deflation will even out the wear. |
11-12-2014, 07:49 PM | #8 |
30
Rep 285
11-12-2014, 07:55 PM | #9 | |
30
Rep 285
I really need to find out about the stock size tires on wider VMR VB3 wheels like I have. Front is .5" wider than the stock size, but the rears are full 1" wider. Anyone have this issues? I need to get to the bottom of this contact patch problem. |
11-12-2014, 08:25 PM | #10 |
19
Rep 260
I had the same problem with my Conti DW and pilot super sports. I ran lower pressure and now I run about 38. I can go through 2 sets of rears before I go through one set of fronts. I think that is just the way it is. Let me know if you have the answer
11-12-2014, 08:52 PM | #11 | |
30
Rep 285
Do you run wider wheels or stock? How many miles did your rear tires last? 38psi is definitely too high for my rears. I was on 36psi and still chewing up the middle area. |
11-12-2014, 09:06 PM | #12 |
1208
Rep 2,835
My wife went through a rear set of Michelin's long before the fronts. These were stock 255/40-17 and ran at the recommended tire pressure.
On the flip side, I went through a front set of General's and inside and outside wore completely off even though I was running higher pressure... even checked the alignment twice. Rears were perfect.... That's the main reason I switched my wagon to a square setup running 255's. I can freaking rotate tires now. |
11-12-2014, 09:51 PM | #13 |
19
Rep 260
My wheels are wider. I'm running a 9.5 in the rear. I was running a 10 with the conti dsw. and you are right I will most likely go through 3 sets of rears before replacing the fronts. I got around 12 to 15 thousand miles out of the rear
11-12-2014, 09:57 PM | #14 | |
30
Rep 285
I had Pilot Sport before and it wore enenly. I'm stumped... I'll stay away from Generals. |
11-12-2014, 10:05 PM | #15 | |
30
Rep 285
More if it wears evenly but it doesn't look like. We're you running stock pressure and stock size tires on wide wheels? |
11-13-2014, 07:31 AM | #17 |
141
Rep 989
Keep your pressure down to about 33-34 when you get the new tires. It looks like your tires are too far gone for it to make a huge difference now.
11-13-2014, 02:54 PM | #18 | |
30
Rep 285
I contacted Michelin and they also recommend BMW specs. I contact God and he says F* IT!!! I think it's Michelin's issue. It's a new tire design from scratch. Why FRONTS 225 don't have problem but rear 255 have it??? I don't wanna have these kind of problems in the future and AVOID MICHELIN PS A/S 3 tires. Although they are good gripping tires and pretty decent warranty, it will last a short life like the more sticky PSS because of this. Product defect is what I can come up with....typical of new product design flaw. I lowered it to 34psi and already seeing terrible fuel MPG!!!!! |
11-13-2014, 02:56 PM | #19 |
81
Rep 1,094
Drives: 2023 G87 M2 6Spd
Maybe doing an alignment may help a bit
[SOLD] 2007 E90 328i - Titanium Metallic l 19" VMR V710 l H&R Trak+ Spacers l M-Sport Rear Bumper l Mtech Rear Lip Spoiler l Hamann Front Lip l Eibach Sportline l AA N52 Signature Exhaust l OEM Blacklines l MTEC V3 AE l 6000K HID l Nokya 7000K Fogs l MTEC License Plate LED l Interior LED l 15% Tint l BlackVue DR380G-HD + PMP
2023 G87 M2 6Spd - HEA Package | OEM M Performance Carbon Wing |
11-13-2014, 03:03 PM | #20 | |
141
Rep 989
11-13-2014, 03:04 PM | #21 |
30
Rep 285
