Kicked OBDII port - broken
11-12-2014, 03:38 PM | #1 |
217
Rep 1,909
I was in a hurry and happened to kick the connector plugged into OBDII while sitting in .. the pieces holding the port broke but ports fine just hanging on its own weight ... Is there a way to fix this,
Mods: 7" VRSF FMIC, Forge DVs, RB PCV, BMS Oil Cooler, VRSF DPs, MHD, JB4g5, OFT DIYs: Walnut blasting : Trans Oil at 45k, w Filter at 65k : Diff Oil Flush @ 45k : WP&TS @ 69k : Alternator @ 79k --- E70d Alphabet Soup del 44.4k : JR Stg2.25 tune : Buzzken Catted Exhaust : Trans fluid drain/ fill (3 Qrts), both Diffs fluids flushed Wheels: Style 95s on PSSs (Sold): AG 359s on S04s : 162s on Blizzaks : Rohana RF1 Matt black
11-12-2014, 04:45 PM | #3 |
533
Rep 2,872
Happened on my old truck! Size 15 boots + OBD port don't work well.
My solution was to buy a blank OBD port, and remove all of the wires from the stock (Broken) OBD port, and transfer them into the new blank port. Keep in mind, if you mis-wire ANY of the connections, it could fry any tool plugged into the connector in the future. Maybe call your local Indy and see what they'd charge to do the swap?
BSM E90 6MT-JB4 G5 ISO-BMS DCI-Golf-Tee Mod-Hankook S1N2 Non-RFT-ER Chargepipe/TiAL BOV-E40 blend-VRSF V2's-M3 CDV-MHD/JB4 FLASH-VRSF 5" STEPPED FMIC
11-12-2014, 04:59 PM | #4 |
Rep 20
The housing part number is 61136954580.
Removing the pins from the broken housing is a pain though, you need to either buy a tool to remove the pins, or make up one (I used 2 drywall knife blades ground down to fit inside the housing) Here is a posting showing removing the pins from the housing. http://www.bimmerboard.com/forums/posts/852232 |
