Should I remove the Thermostat by-pass (Oil Cooler) ?
11-12-2014, 10:49 AM | #1 |
217
Rep 1,909
Hey fellas, with approaching frigid temps here, should I remove the BMS thermostat by-pass ? my gauge this morning didnt even hit 190 F - it was 29 degs outside - I think car runs strong 180 - 190 range but its warming up almost 30 mins after driving, should this be a concern ?
11-12-2014, 11:10 AM | #3 |
61
Rep 722
Yes i would living in chicago especially if you have days of short driving distances your oil may never get to optimal temps and cause more wear
11' m57 335d 165k Miles - JR 2, ATM Full Exhaust & Intake, Wagner FMIC, AAR Boost Pipe, AAR Swirl Delete, AAR EGR Delete
08' n54 135i FBO E85 - SOLD |
11-12-2014, 11:52 AM | #4 |
533
Rep 2,872
I'd remove it for winter, or cold months so the car can get to optimal running temps. Assuming your daily drive isn't long enough to let the car get up to that temp.
11-12-2014, 02:26 PM | #5 |
217
Rep 1,909
My drive's atleast 40 mins each way (60 - 70 miles a day) -
Mods: 7" VRSF FMIC, Forge DVs, RB PCV, BMS Oil Cooler, VRSF DPs, MHD, JB4g5, OFT DIYs: Walnut blasting : Trans Oil at 45k, w Filter at 65k : Diff Oil Flush @ 45k : WP&TS @ 69k : Alternator @ 79k --- E70d Alphabet Soup del 44.4k : JR Stg2.25 tune : Buzzken Catted Exhaust : Trans fluid drain/ fill (3 Qrts), both Diffs fluids flushed Wheels: Style 95s on PSSs (Sold): AG 359s on S04s : 162s on Blizzaks : Rohana RF1 Matt black
11-12-2014, 04:47 PM | #6 |
533
Rep 2,872
Does the car reach normal temps?
BSM E90 6MT-JB4 G5 ISO-BMS DCI-Golf-Tee Mod-Hankook S1N2 Non-RFT-ER Chargepipe/TiAL BOV-E40 blend-VRSF V2's-M3 CDV-MHD/JB4 FLASH-VRSF 5" STEPPED FMIC
11-13-2014, 12:20 PM | #7 |
217
Rep 1,909
11-13-2014, 02:07 PM | #8 |
533
Rep 2,872
As long as the temp rises above the pegged minimum, for a few minutes, I'm sure you're ok. Hell my car barely reaches op. temps and I don't even have an oil cooler. I work 10 minutes from home though.
The only way I could see the car being affected by not reaching normal temps, would be if it rarely reached them. I assume you drive on the weekends and bring the car up to temp so I wouldn't be worried. The only downfall to leaving the stat blocker in would more than likely be a longer time for heat to work. |
11-13-2014, 04:09 PM | #10 |
217
Rep 1,909
really ? heat kills
11-13-2014, 04:23 PM | #11 |
13
Rep 116
It's not about running the oil/engine hotter. It's just the time it needs to get over ~175°F, because it normally takes 10-15 minutes until the engine is warm up and can start driving faster. I never rev the car above ~2500rpm when it's could and accelerate slowly.. but damn 10-15minutes can be a long time when you want to drive your car
