How To Do Burnout In 335
01-06-2008, 12:31 PM | #1 |
28
Rep 82
How do you do a burnout in 335 coupe?
At a complete stop w/ traction off, I can never get the wheels spinning in one place. What am I doing wrong? |
01-06-2008, 12:37 PM | #4 |
28
Rep 82
I drive automatic.
This is what I do: 1st gear tiptronic, traction off, slam the brakes, slam the gas until breaks give up, let go of brakes.... Tires squeal and car starts launching forward. How do you make car sort of stationary while tires are spinning? |
01-06-2008, 12:44 PM | #5 |
1138
Rep 12,444
Can't. Not from my experience at least. Can't bounce off the rev limiter indefinitely or dump the "clutch" at high enough rpms. All I get is a bit of wheel spin and then an eventual launch.
Past: '08 E92 335i|ZPP|ZSP|6AT
Past: '15 Mustang GT|401A|PP|6MT Current: '20 Shelby GT350|6MT |
01-06-2008, 12:46 PM | #6 | |
837
Rep 46,029
i t hink you can for sure. btw, it's a quick way to kill ur tires, just FYI (OP) |
01-06-2008, 12:52 PM | #7 |
88
Rep 764
Drives: 2020 BMW M5 Comp
1.Turn off traction completely
2.put in ds mode (1st gear) 3.hold brake and accelerate until brakes wanna give up 4.let go of brakes until you start burning out 5.brake again to stay burning out in one spot
01-06-2008, 12:54 PM | #9 |
CHEAT TO WIN!!
99
Rep 1,350
I'm not sure, but i think what you do is that you press on the breaks to luck the front wheels then you press on gas to rotate the rear wheels. I might be wrong in saying that the foot break is only for the front wheels, so plz tell me if I am.
Current: 2013 E92 M3, 6MT, SSII on Fox Red Extended
Previous: 2008 E92 335xi, 6MT, AW on Saddle Brown |
01-06-2008, 12:56 PM | #10 |
Back in a BMW
205
Rep 5,208
Its for all four wheels, but only the rears provide power (unless its a xi)
Ian
01-06-2008, 12:56 PM | #11 |
CHEAT TO WIN!!
99
Rep 1,350
are there different buttons for DTC and DSC?
01-06-2008, 12:58 PM | #13 |
CHEAT TO WIN!!
99
Rep 1,350
Thanks, I thought the foot breaks were for the front wheels and the hand break was only for the rear.
01-06-2008, 12:59 PM | #14 |
88
Rep 764
Donut time!
01-06-2008, 01:20 PM | #15 |
8
Rep 263
For an automatic transmission here is a simple way.
1. While carefully modulating the amount of brake applied to ALL four corners, slowly let the car roll into a sturdy concrete barrier. 2. Turn off all traction control and stability inducing devices and/or safeguards. 3. With the car squarely planted on barrier, bury right foot on right pedal. 4. Contact local tire dealer for specials. |
01-06-2008, 01:24 PM | #16 |
39
Rep 388
i usually well first turn off all traction devices (dtc/stabability) hold rpms at around 3k then dump the clutch burry your foot into the gas pedal and then hold the brake with your left foot... but i usually dont do burn outs i like to use thoe precious last bit fo tread in donuts
2007 335i E90 sedan: sport package, montego blue, black interior /w aluminum trim, 6MT
delv: 5/25/07 2010 E82 135i 6MT, Saph Black Ext. , Coral Red Int. , Sport pkg, Cold weather, Ipod/USB, Bluetooth assist. N54 FTW! |
01-06-2008, 01:24 PM | #17 | |
CHEAT TO WIN!!
99
Rep 1,350
01-06-2008, 01:27 PM | #18 |
Da Kid
121
Rep 4,576
its just the control of brakes while ur going WOT at a dead stop
MODS: OEM Front Splitter | ACS Roof Spoiler | OEM Trunk Spoiler | Matt Black Front Grill | Black Shadowline Window Trim | Painted Front Lower Rod | Blacklines | JDM Yellow Fogs | Custom Silver CF Headlights with LUX 4.0 | Eisenhaus Sports Exhaust |
01-06-2008, 01:39 PM | #19 | |
824
Rep 1,584
For my car if I want to do a burnout for 2-3 seconds and eventually launch I rev to 4-5,000 RPMs and dump my clutch quickly, I rarely ever do this and only do it for a laugh because it's pretty hard on your clutch and entire drivetrain (even with the CDV) and in under 10,000 miles my rear tires are completely worn because of the way I drive the car. If you want to do a stationary burnout you do the same but you also hold the brake. I have huge feet so I can cover the gas and brake with one foot without heel and toeing so I use the left part of my right foot on the brake and use the right part of my right foot to modulate the throttle so I don't bounce off the rev limiter too much and keep my left foot near the clutch so I don't stall like a jackass haha. |
01-06-2008, 01:42 PM | #20 |
1138
Rep 12,444
So it's a good way of wasting tread and brake pads. Atleast the pads are under warranty, or so I think.
drukstanas0.00 |
01-06-2008, 01:43 PM | #21 |
39
Rep 388
yeah pads and rotors are under warrenty
