BMS Pump flash help!
11-09-2014, 10:08 PM | #1 |
47
Rep 271
Hey guys need your help here. Just got my car back with some new additions.
VTT Stg 2's 7inch FMIC SteveAZ's Stg 2 Walboro 450 upgrade. I tried flashing tonight for 6 hours with no luck. I used a BT cable and the [Admin Notified] application to try and read my ECU but it took more than 2 hours each try and Terry stated something was wrong so I aborted the read after 2 hours. Tried twice and yes I had a battery tender connected. Volts read at 13.78. Protocol : K Line Software : OI8AOS Variant index : 33 Voltage 13-13.78 Modular preset : true Did some research and found some stating that the 2007 K line ecu's are quite picky. Tried total of 3 times. 2 times : Intel i7 w/16gb ram (fast enough so confused here) 1 time : i5 2gb. Ram Followed the DIY and still not working. Yes JB4 is on map 0. Help please! Want to flash pump flash for daily and e85 flash right before dyno so I can get some info and numbers out to you guys on these VTT's!
E90 - N54 2007 Alpine White FBO :
VRSF CP w/ Tial BOV,VRSF 7 inch FMIC, VRSF Catless DP's, Hexon RR600, Cobb V3, VMR V710 Gunmetal 19x8.5 and 19x9.5, SteveAZ stage 2 bucket |
11-09-2014, 10:28 PM | #2 |
184
Rep 1,702
Drives: Audi TTRS, 335is
Are you getting any error messages at all? KLines are picky. There are two versions of the flashing software. Try Terry's version if you haven't already as it tends to work a little better with KLines.
11-09-2014, 10:42 PM | #3 | |
47
Rep 271
VRSF CP w/ Tial BOV,VRSF 7 inch FMIC, VRSF Catless DP's, Hexon RR600, Cobb V3, VMR V710 Gunmetal 19x8.5 and 19x9.5, SteveAZ stage 2 bucket Last edited by Kienvu14; 11-09-2014 at 10:48 PM.. |
11-09-2014, 10:47 PM | #4 |
47
Rep 271
11-09-2014, 11:36 PM | #5 | |
34
Rep 1,093
Using a windows 8 tablet fyi.
07 335XI (A008006) 6AT ~94K miles JB4 G5 ISO VSRF DP's
09 135I M (VK80379) 6MT. Race Project car. 1) Install Cobb/piggyback? and Motiv 600 Kit[HTA3076R w/ tial .82] 2) JRZ or Moton suspension. 3) Build high flow intake manifold with multi-port fuel and relocate OFH 4) Build full cage 5) Complete staged twin setup with HTA4205R [w/Tial 1.16] 6) Complete dry sump system |
11-09-2014, 11:42 PM | #6 |
BimmerPost Supporting Vendor
1339
Rep 1,701
Drives: Slot Machines.. Keep Taking $
If you want to use Terry's version you need to make sure you have the latest .Net loaded on your computer. If not, update it by downloading .NET which IIRC is 4.5.
Another than you can do is skip the read as you can always recover your ECU from WinKFP. If you need help with downloading the tools, email me. You'll also need a K+DCAN cable which I would recommend for anyone with K-LINE purchase prior to attempting to flash with BB flash. |
11-09-2014, 11:56 PM | #7 | ||
47
Rep 271
11-10-2014, 12:22 AM | #9 | |
47
Rep 271
11-10-2014, 12:46 AM | #10 |
184
Rep 1,702
The .net framework files should be in the Windows update. It looks like you have Win7 so you should have 3.5 or later. With Terry's version (and both versions imo), change the compatibility to run in Windows XP SP2 mode and run as admin. If push comes to shove, find a laptop with WinXP on it and give it a try.
The software is great and free but it is still so buggy :/ |
11-10-2014, 12:59 AM | #11 | |
388
Rep 1,945
11-10-2014, 03:35 AM | #12 |
184
Rep 1,702
11-10-2014, 08:53 AM | #13 |
261
Rep 1,093
I agree. My laptop will not flash my k-line (despite the fact it read it although it took 3hrs). My son's $350 3yr old entry level AMD flashes it ever time in 1:35 sec or faster.
11-10-2014, 12:42 PM | #14 | |
47
Rep 271
11-10-2014, 01:18 PM | #15 |
need4speed
510
Rep 1,903
Doesn't seem to me like the problem is your laptop. Do you have a battery charger connected when attempting to do the read? If not you'll never get a complete read and it'll take about 2 hours do to voltage.
Did you download both the BB software and the BMS software? You can't use the BMS software without the BB software.
N54
11-10-2014, 03:11 PM | #16 | |
47
Rep 271
11-10-2014, 03:24 PM | #17 | |
need4speed
510
Rep 1,903
N54
11-10-2014, 03:37 PM | #18 |
474
Rep 1,544
Is there any stable solution for using BBFlash?
From what I've gathered a few people have bricked their DME using it and a lot of people have slow flash times. It would be nice to be able to use a laptop for flashing along with a VM containing ISTA/D and the standard tools. An all-in-one BMW software tool. |
11-10-2014, 06:58 PM | #19 | ||
47
Rep 271
11-10-2014, 08:43 PM | #20 | |
47
Rep 271
Been reading up. Some say the Kline first read can take up to 6 hours?! Went over 2 hours and gave up for the night, will try again tomorrow morning with a different AMD laptop
