Coolant Leak?
11-09-2014, 05:51 PM | #1 |
Rep 58
Coolant Leak?
What do you guys think this is? My car has 72k and it leaks about 1/4 gallon every 2 days. It's puddles on the right side of the block right underneath the water pump. The top of the hose has all the dried up coolant (pictures ) This is the hose right underneath the turbo piping but above the waterpump. I think the water pump is leaking or spraying some coolant upwards, but could the leak be from the block itself? The dried up coolant is right next to/ underneath the headgasket area.
11-09-2014, 06:04 PM | #2 |
380
Rep 1,497
Have you turned the car on and let it idle while under it to see if it's leaking?water pump has 3 hoses that connect to it.try tightening the hose clamps.might be leaking at the t stat as it's under the turbos,the water pump is more towards the middle of the car
11-09-2014, 06:47 PM | #3 |
44
Rep 359
I just replaced mine at 70k miles. had the same problem, the water pumpe started leaking to the point where i had to add coolant everyday. and it gave out after a couple weeks after it started. if i were you i'd just buy one and get it ready when the other stops working.
11-09-2014, 07:10 PM | #4 | |
Rep 58
11-09-2014, 07:12 PM | #5 | |
Rep 58
11-09-2014, 07:51 PM | #6 |
388
Rep 1,945
11-09-2014, 07:59 PM | #7 |
44
Rep 359
No i didn't get the hoses. I only got the kit with the water pump, bolts and thermostat from Tunermotorsport. you can get the whole kit with the U shaped hose for about $570 or something like that.
11-10-2014, 10:08 AM | #8 |
Rep 58
Here are some more pics taken 24 hours apart. It looks like all the coolant is dried right above the front turbo inlet tubing. Could the leak be from somewhere else off the block?
