Dyno results - FBO 335i with PTF E-Tune and 93 Oct
11-08-2014, 06:45 PM | #1 |
583
Rep 2,233
Drives: '12 M3
Figured I'd post up a real world dyno of a car on pump gas, none of this idealized E85 nonsense :P J/K Huge thanks to Dzenan@PTF for all his help with getting my car running right and making it fast as hell!
Mods:
Conditions: 61.64 °F, 29.47 in-Hg, 19% humidity. EDIT: Got the run files from the shop. Here are the STD #s. Original SAE graph: Run 3 represents the Cobb OTS "Baseline" Map which showed as shockingly lean on my car. Even the PTF tunes (Run 1 and Run 2) are slightly lean in the midrange. Hopefully I can get that sorted out just to be on the safe side. I never expected it to crack 400WTQ, I was expecting around 370-ish, especially as the dyno operators told us that this specific dyno is known as a heartbreaker and reads 5-10% lower than most other shops in the area. In any case, I'm VERY happy with the gains compared to the baseline run (note: this is not a 100% stock run, as the downpipes are on the car, but rather stock-like mapping. Cheers! Last edited by dbworld4k; 11-14-2014 at 10:16 PM.. |
11-08-2014, 07:35 PM | #3 |
9
Rep 305
Yeah and Why a heartbreaker dyno? This is a dynojet for god sakes. Not talking about typical load dynos that consistently run lower figures. Sorry but not trying to dishearten you but a jb4 does much better than that for the mods and fuel you run. 365 whp was what I got the day I installed my jb4 spun on a brand new 224x dynojet some time last year which is consistent with what most will get and I baselined 272 then. Pure 93 oct on stock intercooler. But anyway as long as you're happy that's what matters.
11-08-2014, 07:47 PM | #4 | ||
583
Rep 2,233
Drives: '12 M3
Your dyno numbers are meaningless to compare to another car at a different shop at a different day. Absolute dyno numbers are meaningless. Last edited by dbworld4k; 11-08-2014 at 07:55 PM.. |
11-08-2014, 08:18 PM | #5 | ||
Power is nothing without control
33
Rep 762
In your first post, you say that the Run 2 was the OTS map. Is that correct? So they put down about the same as the Run 1 which you say is PTF. Quote:
11-08-2014, 08:50 PM | #6 |
583
Rep 2,233
Drives: '12 M3
Woops, my mistake. I should've said Run 3 was the Cobb OTS Baseline map. No Cobb OTS Baseline map makes anywhere near 330 and 400 lol. The OTS Baseline maps are meant to simulate stock BMW mapping.
PTF runs were # 1 and 2. Hope this clears up the confusion! |
11-08-2014, 09:59 PM | #7 |
34
Rep 783
Excellent results for 91 octane! Very consistent runs. Do you have any higher octane in your area or maybe meth? With all that torque on just 91 octane the car must be a fun daily driver without impact to fuel mileage like on E85. I wonder what STD numbers say too. SAE tends to read quite a bit lower.
11-09-2014, 01:23 AM | #9 |
24
Rep 131
Your correction factor above is only 0.98 so it's actually reading lower than what the car was physically putting down. 2% lower to be exact. This is due to temp/barometric pressure/humidity being better/more ideal than the sae standards that are input from dynojet. STD correction is typically 1.04. Uncorrected (what it physically was putting down) should be around 343whp and 410wtq.
Also, your fuel curve is very lean. I'd be cautious and find out if it was the dyno sniffer reading wrong or if that's your actual fuel curve. If it is actual then it needs to be fattened up. Might explain why it seems to be making less power than what others have made.
-E92 335i: Montego blue/saddle brown, FFTEC TM 6466, Haltech PS1k EMS, Motiv PI-1000, Fuel-It Hulk stg3+, Cobb AP, VRSF IC, 4" exhaust, Clutchmasters fx850, msport front, Akrym CF lip, M3 sides, mtech rear, cf diffuser, csl cf wing, DPE SL5's **N54 Record holder 861whp@36psi** (click)
-'93 MR2: tons of mods, all fab work, assembly, and tuning done by me. 675whp@24psi, 40psi unknown (800+whp), 900+whp to come. Dyno vid Last edited by MR2 Josh; 11-09-2014 at 03:47 PM.. |
11-09-2014, 08:22 AM | #10 |
34
Rep 783
AFR dyno sensor seems to just be reading 1 point leaner even with the stock map. I would say the sensor just was not pushed in far enough down the exhaust pipe and is picking up some ambient air. I know PTF targets their fuel on pump gas in high 11s in the higher rev range and no way it is that lean.
This dyno seems lower reading than average as a lot of Dynojets will show stock numbers at 290-295 range with those mods on the car. This one is with downpipes and intercooler at 280 putting the stock car at probably 250-260 range at the wheels. |
11-09-2014, 11:03 AM | #13 |
33
Rep 762
Makes sense now. I thought you meant that was an OTS stage 2+ or something and so I thought the PTF tweaking didn't give you any gain over that. Good stuff.
11-09-2014, 02:28 PM | #14 |
DisplacementReplacement
409
Rep 1,102
I guess what would have been nice is to see map 0, OTS and the pro tune. Map 0 could have been the baseline, would be nice to see the pro tune in relation to the OTS. JMHO!
11-09-2014, 11:02 PM | #15 | ||||
583
Rep 2,233
Drives: '12 M3
FWIW, I ran a Dinan S2 E39 M5 tonight that is known to be neck and neck with E92 M3s. He put down around 380whp and 345wtq. Did 5 runs against this M5 and I pulled every singly time from 40-130. Ended with me being about 1.5-2 cars ahead. Needless to say, this thing MOVES!
Thanks! Quote:
I'll post an update once I get the uncorrected numbers. Quote:
I agree whole heartedly! Unfortunately, the OTS Stag 2+ Cobb map simply won't work on my car when I go past 1/3rd throttle. It always triggers limp mode. I wish it worked, because it would've been the perfect dyno run with a run each at Stage 0, Stage 2+ OTS, and then PTF... |
11-10-2014, 08:32 AM | #16 | |
135
Rep 692
Beauty of running real gas (93) vs. crap ACN 91 -- Allows you to run a much more aggressive boost curve along with achieving the timing curve, minimum timing corrections.
Results > |
11-14-2014, 10:22 PM | #17 |
583
Rep 2,233
Drives: '12 M3
STD corrected graph uploaded!
Hope this helps. |
11-14-2014, 11:12 PM | #18 |
25
Rep 755
Dbworld4k, thanks for sharing your PTF e-tune results! Will you be getting another e-tune to take advantage of the 93 octane fuel?
Car: 2007 e90 335i 6MT - sports, premium, cold weather, light, and smoker's package. Performance Mods: Cobb AP v3, ETS 7" FMIC, Injen DCI, Michelin PSS, CDV delete, rear spoiler, BMW PE w/ Magnaflow tips, PTF pro-tune, VRSF downpipes, ER chargepipe w/ Tial Q, APEX 18" EC-7 wheels, MP outlet/ inlet, MMP Stg. 3 turbos. Other mods: BMW cargo liner, 20% window tint, BMW alarm system, Weathertech floorliner, Lux E90 V6 bulbs, Philips X-treme Vision H7 bulbs, Blackvue DR650GW-2CH.
11-15-2014, 10:06 AM | #19 |
34
Rep 783
I would add meth on there eventually to squeeze quite a bit more with the added octane.
'07 335i E90 - PTF ProTUNED by Dzenno - COBB FMIC - AFE DCI - AA DPs - HFS4 Meth
'09 M3 - Stock |
11-16-2014, 12:40 AM | #20 | |
583
Rep 2,233
Drives: '12 M3
11-16-2014, 06:05 AM | #21 |
34
Rep 783
I saw a discussion on Facebook on this. Its a 91 octane map and it does this with just 13.5psi where peak power is made because of 91 octane. Now imagine what these guys can do if they upped boost on higher octane.
'09 M3 - Stock |
11-17-2014, 10:16 AM | #22 |
Guest
Rep n/a
Drives:
No need to "imagine" anything...it's been done 1,000+ times already lol
