Autotalent
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Track / Autocross / Dragstrip / Driving Techniques
      11-07-2014, 11:46 PM   #1
MpowerLex
MpowerLex's Avatar
Drives: 2016 M3
12.03 1/4 mile run Bone stock M3!
First time at the track. Was a busy night so was only able to get 3 runs in. Overall I feel pretty good about my times. I would have broke into the 11's if I would of remembered to adjust my tire pressure so I could hook up a lil better, but this time was done at 31psi, 93 oct gas, no mods, with a miss shift from 2nd to 3rd. I thought that I was shifting since I did launch control and was in manual mode, but the car shifted and so did I and instead of going into 2nd the car skipped and went to third. Next week I will deff get into the 11's.
      11-08-2014, 12:09 AM   #2
MpowerLex
MpowerLex's Avatar
Drives: 2016 M3
Pics
      11-08-2014, 01:51 AM   #3
Vectors2final
Vectors2final's Avatar
Drives: 2018 F80 YMB/SS ZCP
wat?
      11-08-2014, 01:56 AM   #4
crand002
11
Drives: Audi
Slips please.
      11-08-2014, 05:31 AM   #5
MpowerLex
MpowerLex's Avatar
Drives: 2016 M3
Second attempt at pics
      11-08-2014, 05:45 AM   #6
Tony007
Tony007's Avatar
56
Drives: 17 M3 ZCP
awesome run!!
      11-08-2014, 05:55 AM   #7
MpowerLex
MpowerLex's Avatar
Drives: 2016 M3
      11-08-2014, 06:25 AM   #8
MpowerLex
MpowerLex's Avatar
Drives: 2016 M3
      11-08-2014, 06:28 AM   #9
MpowerLex
MpowerLex's Avatar
Drives: 2016 M3
      11-08-2014, 07:04 AM   #10
dmk08
Gone Fishin’
dmk08's Avatar
Drives: Walks
Awesome. How did you miss shift DCT?
      11-08-2014, 08:05 AM   #11
MaynardZed
MaynardZed's Avatar
Drives: wife crazy
Sounds like he double shifted, once automatically by the car and once himself.
I'd say it would sound completely implausible to run 12 flat while totally skipping 2nd gear. But I've driven the car on a road course and the torque in 3rd gear is tremendous and it pulls really hard even from 30-40 mph.
Road course laptimes for BMW M4 2015 6MT
WHP East Track: 1:04.880, Arizona Motorsports Park: 1:54.352
Road course laptimes for Porsche 911 991.1 GTS 7MT
WHP East Track: 1:02.770, Arizona Motorsports Park: 1:48.889
      11-08-2014, 08:40 AM   #12
CanAutM3
CanAutM3's Avatar
21115
Drives: 2021 911 turbo
Nice time . Even more impressive if it was done with a bad shift.
You need to be in manual (S) mode to be able to engage launch control. But as long as launch control is activated, DCT will upshift automatically. It is a bit counter intuitive. Launch control will deactivate if you shift manually or slightly lift off the throttle pedal as to disengage the "kickdown" button.
      11-08-2014, 01:13 PM   #13
nicknaz
nicknaz's Avatar
3187
Drives: C6Z
Will the DCT upshift automatically at redline in other modes (i.e. in manual mode) outside of launch control?
Nice run OP
      11-08-2014, 01:24 PM   #14
MpowerLex
MpowerLex's Avatar
Drives: 2016 M3
I will be going again next week. I will be lowering the tire psi, letting launch control does do the shifting with out me trying to manually do it, and raise the rpms to about 3500. If I get all this right, it should very easily break into the 11's.
      11-08-2014, 01:24 PM   #15
MpowerLex
MpowerLex's Avatar
Drives: 2016 M3
The car shifted on its own and at the same time I shifted so it skipped 2nd and went right into 3rd.
      11-08-2014, 02:06 PM   #16
CanAutM3
CanAutM3's Avatar
21115
In Sequential (manual) mode, DCT will not upshift automatically unless Launch Control is activated. The engine will go up to redline and then bounce on the limiter. This is where it gets tricky. If you do a Launch Controlled launch and inadvertently lift off the throttle during the acceleration run (this will deactivate LC), the engine will bounce off the limiter when you expect it to upshift automatically. Bottom line, keep the throttle pedal pinned to the floor during LC.
Note that DCT will downshift automatically even in S mode when the RPM drop to low to avoid bogging down the engine.
      11-08-2014, 10:04 PM   #17
MpowerLex
MpowerLex's Avatar
Drives: 2016 M3
This is good info, should deff help solve the issues I was having. Thanks for your input.
      11-17-2014, 08:37 PM   #18
wantm135i
wantm135i's Avatar
Drives: x1 35i m sport
you probably just learned the bmw in house trick iam sure the boost is higher in 3ed gear vs 2nd. thats how you run low times, or dont shift at red line to run 12 sec 1/4 mile runs.
f80post
