E85 questions...
11-07-2014, 02:36 PM | #1 |
426
Rep 2,136
E85 questions...
Hello all,
I will be driving to a gas station this week end where I can get E85. I have never tried putting E85 in my tank before. Unfortunately there is no E85 station within close driving distance to where I live My questions are, what ratio E85/93 can I safely use to start with? Can I even put E85 in my tank knowing I only have a G4 board and not a G5 board, and no backend flash? Current mods: JB4 G4, DCI, Downpipes, Charge pipe. Thanks,
JB4 G5 w/ Backend flash - Walbro 450lpfp - VRSF DPs - VRSF 5" stepped IC - DCI - ER CP w/ Tial BOV - 335is clutch |
11-07-2014, 02:45 PM | #2 |
25
Rep 414
Drives: 2009 e90 335i
I don't have a JB4, but I ran 3 gallons of e85 and the rest 93 to help clean up some timing corrections before I got an e85 tune. You really just have to pay attention to your lpfp pressure to make sure you don't have consistent drops into the low 60s.
2009 e90 335i | AT | AG M590 | Conti DW | KW V1 | Lux | Akebono
e50 PTF Protune | Cobb FMIC | aFe DCI | VRSF DPs | ER CP | Tial BOV | Alpina Flash | Fuel-It Stg1 | RB PCV | Cobb Exhaust |
11-07-2014, 02:47 PM | #3 |
40
Rep 823
Drives: 2008 335i Coupe TIAG
I've been doing a little homework on this subject too, but I only have 91octane around me. just google "n54 e85 93 mix" and the first 4-5 results (all from e90post) have a lot of very good/interesting information regarding mixing fuel with e85.
11-08-2014, 12:37 AM | #4 |
32
Rep 208
Start with 3 gallons of e85 to 8 gallons 93 octane map5 you will def feel the difference. It is also not problem that you have g4. Move up the content if you know how to log and what to look for.
11-08-2014, 08:36 AM | #5 |
426
Rep 2,136
I put 4.5 gallons of e85 to top up the tank (that should be about 30/70 e85/93 ratio) and damn the car is FAST! WOT in 2nd gear and the rear wheels break loose completely on dry pavement, no grip! Third gear on e85 feels like 2nd gear on pump gas now
I'll do some logs today to check how the low pressure fuel pump is doing... |
11-08-2014, 09:35 AM | #7 | |
533
Rep 2,872
Russell over at N54Tech really helped me dial in the perfect E85 ratio for my car, especially not having the backend flash, so I recommend posting a log over there too that way you'll know how much cushion you have for next time you get more magical corn juice! |
03-21-2015, 01:54 AM | #8 |
Walter White
8
Rep 83
Sorry to sort of hijack this thread, but I am currently running on only a dci and upgraded charge pipe and bov. What can I do to make my car ready for e85? or could I use it already? I just really want to know because I live 5 minutes away from the nearest shell that sells e85
03-21-2015, 11:43 AM | #9 |
291
Rep 2,189
If you can't get E85 on a regular basis I wouldn't even try it.
It will ruin your experience on pump gas for good.
2007 E92 335 6MT w/335is clutch FBO MHD E60 Wedge map 49k miles
03-21-2015, 12:18 PM | #10 | |
533
Rep 2,872
If you don't have a tune, don't waste your money on E85. The car will not adjust in a good way for the fuel. |
03-21-2015, 08:55 PM | #11 |
Walter White
8
Rep 83
The jb4 is definitely next on my list, but you're saying I can just fill my tank with 70% 93 and 30% e85, set to map 5 and I'm ready? I've heard some people say there are some things you should upgrade first like maybe injectors before you start using it. I have no idea, I have no experience with e85 at all lol
03-21-2015, 10:38 PM | #12 | |
533
Rep 2,872
Dump some in, I filled my car to 3/4 93, and the rest E85, however you can start with a lower amount and work your way up as you get adjusted to it. Most important thing to do is datalog through the JB4 interface, and make sure everything is happy on the new found power. Post the .csv file from the log into the support section at N54Tech.com for Russell to review and confirm everything is ok, if you can't read them yourself. |
03-22-2015, 01:21 PM | #14 | ||
Walter White
8
Rep 83
03-22-2015, 01:57 PM | #15 |
426
Rep 2,136
JB4 alone will make enough power for you to beat a 370z if he's stock.
03-22-2015, 02:07 PM | #16 | |
Walter White
8
Rep 83
03-22-2015, 02:25 PM | #17 |
48
Rep 342
03-22-2015, 03:53 PM | #18 |
533
Rep 2,872
I hope he did Dyno at 350hp. A 335 w/ a tune & DCI a will make 370hp all day long. Find him on the road and give him another run! on a closed course ofcourse.
03-22-2015, 04:07 PM | #19 | |
Walter White
8
Rep 83
