My car shut off while coming to a stop at 10mph
11-06-2014, 07:00 PM | #1 |
34
Rep 394
Guys i've been having problems with my car lately not sure exactly what but just now I was slowing down to a stop sign and it just shut off at 10mph. Steering wheel locked couldnt gas, couldnt take the key out. After trying several times 15 seconds later It turned back on. Has anyone heard of anything like this?
MHD- VRSF Catless Downpipe - VRSF Charge Pipe - VRSF 7" FMIC - aFe Intake - Alpina Flash - Pure Stage 2 - Pure Inlet - Fuel it! PI - Fuel it! Stage 2 LPFP - N20 3.5bar Tmap sensor - N20 spark plugs -
11-06-2014, 07:15 PM | #2 |
324
Rep 2,014
That's crazy man. Have you checked for any codes?
WedgePerformance E40 MHD | Performance Exhaust Mod | BMS DP | Vibrant 1790 | BMS Intake | VRSF CP | xHP Stage 3 Michelin PSS | M3 Control Arms LUX v4 LEDs | Shadowline Grills | Lip Spoiler |
11-06-2014, 07:19 PM | #3 |
34
Rep 394
11-06-2014, 07:27 PM | #4 |
34
Rep 394
*"the connector for the positive battery cable connector and the corresponding terminal on the fuse box may degrade over time," which can eventually lead to a break in the electrical connection and a loss of power in the vehicle. If the car loses power, the engine can stall, which could possibly lead to a crash."
Could my car be part of this eletrical problem recall thing? It says 07-11. Mine is made in Dec of 11 |
11-06-2014, 07:34 PM | #5 |
315
Rep 929
Drives: 2011 BMW 335i xDrive manual
You have to download the jb4 interface. It's somewhere on the n54tech forum. Do you use spacers between your o2's and down pipe?
11-06-2014, 07:51 PM | #6 | |
37
Rep 504
Drives: BMW 335xi 2011
11-06-2014, 07:57 PM | #7 |
34
Rep 394
11-06-2014, 07:58 PM | #8 |
34
Rep 394
11-06-2014, 08:17 PM | #9 |
15
Rep 152
Drives: 2007 328i Coupe
Thats really dangerous, i hope you get the problem fixed soon man. Until then drive safe!
11-06-2014, 08:28 PM | #10 |
315
Rep 929
A lot of people have been trying out spacers or "mini-cats" on cat less down pipes (myself included) in order to keep away that check engine light for a while longer. It works pretty well too as long as you only put one in between the rear O2 sensor and the dp. If you put one between the pre-cat O2 sensor and the dp, which a lot of people have done, it causes idle issues and intermittent stalling due to the O2 responding incorrectly. Unfortunately if a jb4 is set to auto clear it'll clear the specific code it throws (p0133 or p2cf4), which points to a fault in the pre-cat O2
11-07-2014, 12:17 AM | #11 | |
34
Rep 394
11-07-2014, 12:19 AM | #12 |
34
Rep 394
Thanks man and yeah also I can never get through any red lights anymore without my car jerking and rpms dropping while holding the brake. I have to put it in neutral I feel like im gonna hit the car infront of me.
11-10-2014, 08:32 PM | #13 |
34
Rep 394
Wow this is ridiculous, car is shutting off at least 3x a day now, and every time I stop now it feels like it's about to stall. Rpm tachometer wiggles up and down and car dies out. It literally stalls on me lol. Calling BMW tomorrow!!!!
11-10-2014, 09:21 PM | #14 |
324
Rep 2,014
Do you still have the issue when the JB4 is uninstalled?
11-10-2014, 10:20 PM | #15 |
Rep 43
If it was a cable aka electrical you'd have other problems besides just shutting down. How's your idle? Check your vacuum lines (most likely cause imo) and fuel pressure too... I would suggest bringing it to an indy shop, might be something simple.. Good luck
11-11-2014, 10:44 AM | #16 |
34
Rep 394
I didn't have this problem before the Jb4 was installed. However I put it on Map 0 yesterday with no e85 and car had the same issues. I think your right it most likely may be a vacuum line problem or maybe need to update DME.
11-11-2014, 11:06 AM | #17 |
324
Rep 2,014
AFAIK, those vacuum line issues are specific to N54s. I may be wrong on that though.
11-11-2014, 04:43 PM | #18 |
315
Rep 929
Autoclear off and still no codes?
11-11-2014, 07:00 PM | #19 |
34
Rep 394
I don't know how to check the codes. What software or program do I have to download?
11-11-2014, 09:33 PM | #20 |
34
Rep 394
Oh wow guys I think I figured it out. I've tried plugging back in my Golf Tee Mod Vacuum Line while I had my muffler delete and the car still kept turning off. Now I just tried re-connecting the vacuum line with my stock mufflers back on and my car hasn't turned off on me or jerk while idle. So happy though, I think this fixed it. For now
