Latest Progman Software
01-05-2008, 12:28 PM | #1 |
324
Rep 2,663
Drives: BMW 335xi Sedan; BMW M3 ZCP
What is the latest Progman software?
What is the latest SIB#? Link to all SIB after Progman 27.00.00? |
01-05-2008, 08:41 PM | #2 |
324
Rep 2,663
Bump
01-05-2008, 11:11 PM | #4 |
384
Rep 21,747
Drives: E92 335i TiAg/E46 323i TiAg
i have 27.2.1
07 E92 335i | TiAg | Step | Padl | Cmft | Alum Trm | PDC | Nav | Assist | Sat | Lthr | Prem | Sprt | Rear Splr | RDSport Quads | iPod | V1 | LT Refl | VS Clear Bra | OEM Lip | KWV2 | Mtec Sides | BBS LM-R
00 E46 323i | TiAg | 5sp | Sport | Roof | RDSport Cams | RDSport tune | RDSport Shift | Volk LE37 | M3 spoiler | PSS9 | SuperSprint | Brembo |
01-06-2008, 12:19 AM | #5 |
Bad Lieutenant
232
Rep 3,517
^^^^ Ditto
02 E39M5 | TiAg/Schwartz | Tubi Rumore | Ultimate Ti Pedals | E60 SSK | Jim Blanton 3.45 40/100% | Coby Alcantara | StrongStrut STB
01-06-2008, 10:51 AM | #7 | |
45
Rep 1,738
Even with i-Drive you can't tell. The only way to know is through the dealer.
2006 325i - Sparkling Graphite
2000 S2000 - New Formula Red 2007 Chev Silverado crew cab Z71 |
01-06-2008, 10:59 PM | #10 |
324
Rep 2,663
I did the trick by holding down the trip monitor for 10 seconds. Does it states there what version of Progman you have?
01-07-2008, 01:20 AM | #11 |
384
Rep 21,747
You will have to ask the dealer when they program it.
Make sure you ask them ahead of time. If you ask when you are closing out your invoice, they will just say "the latest one"... or "I think it's 27.x"...
01-07-2008, 01:21 AM | #12 |
324
Rep 2,663
no, im talking about doing the hack by holding down the trip button for 10 seconds. try it and then go to #5.
Accessing the menus To access these hidden menus (or service menus). 1. Turn ignition on, or start your car 2. Press and hold the button to reset the daytrip/odometer for 10 seconds To continue to navigate the menus, you need to use again the daytrip/odometer button (hereafter just called 'button') Last edited by AltecBX; 01-07-2008 at 01:42 AM.. |
01-07-2008, 08:00 AM | #13 |
67
Rep 527
Does it really matter what the latest software is? I just installed 28.0 into our Progman's if you need to know, but if you're not having any problems with the car software is a waste of time.
10 AW on fox E90 M3 with 2 pedals, gentleman’s ride
08 AW on fox E92 M3 also 2 pedals, a bit more rowdy |
01-07-2008, 08:05 AM | #14 |
Critical Care Anesthesiologist
481
Rep 8,828
Drives: SMB F83
It doesn't. Unless you are trying to reprogram / recode your car. I'll need a full Progman update to get my headlight SMC/AHL module recoded, as well as attempting PDC retrofit.
kev { divinum est sedate dolorem }
"your friendly neighborhood critical care anesthesiologist" |
01-07-2008, 08:14 AM | #15 |
324
Rep 2,663
My car keeps switching my ipod to FM mode and when I stop my car, it feels like I'm getting hit all the time from the back.
01-07-2008, 10:36 AM | #16 |
Freude am Fahren
336
Rep 5,254
It doesn't matter what the latest is but if you are trying to figure out what features you are missing (i.e. what features were added at a particular point such as the "missing" guidance arrow which was reintroduced with Progman 23.x) or trying to figure out if a new version of Progman will resolve an open issue, then it matters.
Freude am Fahren.
Jonathan E90 2006 330xi E90 2006 325i E39 2003 530i Sport* E46 2000 328Ci* E36 1996 328iS* E36 1992 325i* E30 1991 318is E21 1982 320iS* E21 1979 320 (6-Zyl)* *retired Nominated: Most Contributing Member |
01-07-2008, 05:34 PM | #17 | |
E90 convert
Rep 21
http://www.e90post.com/forums/showth...=square+wheels I had the Progman updated and that issue has been solved - I believe it will also solve the iPod thing too? (I don't have one so couldn't tell ). A unfortunate by-product of this updated Progman though is the return of the throttle lag I was used to in my previous E46s. I'm hoping it will improve as the car re-learns? Main point though is that I can now stop without the lurch. Man that was driving me nuts! |
01-08-2008, 07:20 AM | #18 |
67
Rep 527
28.0 will fix your Ipod problems guys, it's a documented fix. As far as the transmissions go I know nothing about a software fix. Does it feel like a harsh 2-1 downshift? Remember that when the trans control module is programmed the adaptations are reset which will drastically change the way the trans shifts for a while after the update.
01-08-2008, 09:48 AM | #19 |
324
Rep 2,663
Where is the document of the Progman 28.0?
01-08-2008, 04:20 PM | #20 | |
this is the way
18151
Rep 8,527
01-08-2008, 11:34 PM | #21 |
324
Rep 2,663
Can't find anything on the Progman 28. Is this really real, or is 27.02 the latest one.
01-08-2008, 11:57 PM | #22 |
384
Rep 21,747
As of a few weeks ago, 27.02 is the latest. My friend has it and it fixed his iPod/FM issue.
