JB4 install: Leave flex fuel wires unplugged?
11-06-2014, 01:03 PM | #1 |
E90 2011 335i m-sport package
Rep 72
Hi everyone,
I live in Canada where we can not have E85. I'm about to buy a used JB4 Gen5 ISO and the flex fuel clips are on the harness. I'd like to know if I have to plug the flex fuel clips even if I will not use e85 or I can leave them unplugged and be just fine. thanks 2011 335i msport |
11-06-2014, 01:32 PM | #2 |
28
Rep 583
If the wires are installed on the harness you must plug them in. You could remove he flex fuel wires by reconnecting the intercepted green wire on the harness and changing the fuel use setting back to normal
JB4 G5 ISO FF | BMS Performance Intake | BMS Wheel Spacers | VRSF Catless DP | Red CYBA Scoops | Supreme Power Lowering Perches | VRSF Charge Pipe | VMR 810 19x8.5 ET35 19x9.5 ET33 | Michelin PSS 235/265 | BMS CDV | BMS Clutch Stop | 4'' Tips
11-06-2014, 01:32 PM | #3 | |
315
Rep 929
Drives: 2011 BMW 335i xDrive manual
11-06-2014, 01:55 PM | #4 |
Rep 72
Thanks for your fast answer, I guess the best would be to plug them but they seem to be pretty hard to connect compared to theother clips of the jb4.
If I understand well, I could disable the ff wires by setting "fuel open loop" to 0 on the jb4 user adjustments and drive with the ff wires unplugged? |
11-06-2014, 02:32 PM | #5 | |
315
Rep 929
11-06-2014, 02:47 PM | #6 |
Rep 72
ok Thanks again, I will plug those ff plugs and set open fuel loop to 0 and leave it there.
Being connected, I'll have the option to test e85 on an eventual road trip to the usa next summer! Installing a used jb4, should I erase the existing maps and download the latest via bms? |
11-06-2014, 03:27 PM | #7 |
245
Rep 1,595
Drives: 2011 335i xDrive Msport
I would update to the latest ISO firmware, no reason to mess with any maps as only Map 6 is user adjustable, the rest are set.
11-06-2014, 08:13 PM | #9 |
28
Rep 583
just to clear it up since you kind or worded that weirdly you don't have erase anything, just download the latest hex and update the jb4 with it, no erasing necessary. good luck!
