Vacuum and Boost Questions!
01-05-2008, 11:10 AM | #1 |
Modder Raider
753
Rep 8,633
Drives: M3
Hey guys,
I finally installed my boost gauge yesterday after getting everything I needed for the install. I'm really happy with the results, but I have a couple questions so I can verify that the readings that I'm getting are accurate. I have the Procede v1.47 currently installed and UR catted DPs. At idle, I'm getting 18 In Hg. At full boost I'm getting 12ish PSI. I'm at sea level. Could you please provide the following for me so I can compare the numbers to make sure that there are no leaks with mine? Please have the reaidngs be CURRENT. - Tuner program - Exhaust - In Hg at idle - Peak boost - Your elevation Please don't turn this in to a pissing contest; like...Oh yah, well I peak at 20 psi all the time bla bla bla. Thanks a bunch! Here are the final pics.
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
01-05-2008, 11:21 AM | #2 |
137
Rep 6,608
Looks good! Did you actually screw it down, or just sit it up there with that bracket?
I install all tunes, intakes, o2 simms, and most cosmetic mods. PM me for a quote. |
01-05-2008, 11:27 AM | #3 |
50
Rep 1,600
Drives: e90 335i
Did you or can you print up a DIY? That looks pretty darn good. What gauge is it and how much did you pay for it?
01-05-2008, 11:32 AM | #4 | |
Modder Raider
753
Rep 8,633
Drives: M3
This is an STRI gauge. I posted this poll regarding the placement, but I think that a lot of people had problems with how I was going to mount it. http://www.e90post.com/forums/showthread.php?t=104461
01-05-2008, 11:33 AM | #5 |
Perf BMW mag issue 147, 159
414
Rep 6,803
Looks good man! I am getting about the same vacumm as well. In the mornings its really low at like 5 hg then it will get to like 10hg then 15-18hg. I have Xede with CP-E exhaust. Boost is around 13psi. Dont know the elevation in FL.
'13 Estoril Blue 335i M-sport
*Don't PM me!* Message me here- http://www.facebook.com/ProjectEstoril |
01-05-2008, 11:38 AM | #6 | |
Modder Raider
753
Rep 8,633
Drives: M3
I have a feeling that the pressure fitting that came with the original vacuum line didn't fit a tight seal with the new black line that I got.
01-05-2008, 12:07 PM | #7 |
39
Rep 726
Looking good! What is holding the 'Gauge' in the lower Exhaust Flange?
Thanks, Dave
2010 ZR1 3ZR Wht/Blk 10.7 @ 132
2011 C63 AMG P31 Car Blk/Blk 11.8 @ 117 2010 Nissan GT-R 10.8 @ 129 (Sold) 2008 Lexus IS-F (Sold) 12.5 @ 113 / 2008 Shelby GT500 (Sold) 11.3 @ 126 2008 e90 M3 6MT 12.8 @ 111 (Sold) / 2006 e60 M5 12.4 @ 114 (Sold) |
01-05-2008, 12:14 PM | #8 | |
Modder Raider
753
Rep 8,633
Drives: M3
In post 4 you'll see a link. We talked about most of what you PM'd me about in that link. The exhaust flange I got at Autozone. The gauge I got from here: http://www.ravspeconline.com/shop/ca...oducts_id=1724 As far a s a DIY, I'm too lazy right now. Maybe later.
01-05-2008, 12:15 PM | #9 |
Chief Executive
300
Rep 2,886
Drives: 2008 335xi 6spd Coupe
My guess is he just tightened the flange around the guage cylinder |
01-05-2008, 12:21 PM | #11 | |
Modder Raider
753
Rep 8,633
Drives: M3
I have a feeling the pressure fitting was too big for the vacuum line. What mods do you have?
01-05-2008, 12:32 PM | #12 | |
218
Rep 4,726
And I have 20-22 stock as well.
01-05-2008, 01:02 PM | #13 | |
Modder Raider
753
Rep 8,633
Drives: M3
I just wanted to make sure that it sealed correctly. I know there's no flow, and as far as hearing hissing, I don't know if I would be able to tell over my exhaust.
01-05-2008, 06:21 PM | #15 | |
Modder Raider
753
Rep 8,633
Drives: M3
You don't have to have a piggyback to put in a boost gauge. One could install one to see what their stock boost is. Plain and simmple: Boost gauges are fun-tuned or stock.
01-05-2008, 06:28 PM | #16 |
Moderator
270
Rep 4,481
Removable VEI Systems digital vac/boost gauge
- Tuner program: PROcede V2, 90% - Exhaust: stock - In Hg at idle: -18 ( -23 downhill or lifting the pedal ) - Peak boost: 13.8 plus 0.6 baseline - Elevation: 1800 feet |
01-05-2008, 06:42 PM | #17 |
Modder Raider
753
Rep 8,633
Drives: M3
Thanks man.
I appreciate it. It looks like mine is fine by the vacuum being the same with you guys. I'll drive around a bit more to see if there is any fluctuation with the boost. There's also a possibility that the gauge isn't as accurate.
01-06-2008, 12:14 PM | #18 | |
330
Rep 1,084
Thanks! -Rob |
01-06-2008, 12:46 PM | #19 | |
Modder Raider
753
Rep 8,633
Drives: M3
I'll take a pic tonight. I have a slight problem though. I just went driving and it was the first time driving in the day time with this gauge. It was very hard to see with all of the light coming in. I either have to go with a clear lense or get a different coverthat helps cover the gauge from the external light.
01-06-2008, 12:47 PM | #20 | |
137
Rep 6,608
01-06-2008, 01:30 PM | #21 | |
Modder Raider
753
Rep 8,633
Drives: M3
It's worse with sunglasses. I found this and I wonder if this would help:
01-06-2008, 01:32 PM | #22 |
Modder Raider
753
Rep 8,633
Drives: M3
Here's another one:
