Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > 2E83 After Waterpump Replacement
      11-05-2014, 06:42 AM   #1
Tzu
29
Drives: 335i
My waterpump finally gave out. Codes 2E83 and 2E84. I replaced it with a VDO spare I had purchased a while ago (latest 426 revision) and cleared codes.
During the bleed process, I kept getting 2E84 "Communication" error and the pump would sometimes not respond to manual initiation in INPA. Cleared it and drove around the block with INPA connected to monitor coolant temps. Codes cleared themselves and seemed to operate fine for 45 minutes; figured it was one of those diagnostic codes that may only clear with the engine running.
Drove it to work this morning, and got 2E83 "Waterpump Low Power." Any of you guys still getting codes after waterpump replacement with the VDO setup? I checked all fuses, distribution block, verified waterpump pin voltages. Pump seems to have adequate duty cycle variance while driving and no overheating.
New pump on the fritz already?
      11-05-2014, 10:31 AM   #2
4doorbmwpower
4doorbmwpower's Avatar
Drives: Montego Blue E90 335i
let me know if you find anything out i will be installing my VDO in a weeks time
cp-e GTX3071R TT kit, cp-e quad exhaust, cp-e fuelbar, Stage 3 LPFP+lines, AEM EFI, Custom Meth kit, Apex EC7 18s w/R888 295s, Stoptech, M3 front, m-sport rear, cp-e difuser, Custom Headlights, CFS Radiator, Custom OC, 1000hp Lvl10 trans, DSS Axles, MFactory LSD, DEFIV lockdown kit, M3 refresh kit, KWv2's, cp-e project "4doorbmwpower"
      11-10-2014, 07:20 AM   #3
Tzu
29
Drives: 335i
I dont think the VDO is the issue, they are an OEM manufacturer. Something else is amiss here.
      11-10-2014, 12:15 PM   #4
Bavarian Tech
Bavarian Tech's Avatar
267
Drives: 335i
2006 330i  [10.00]
I have had two OE water pumps out the box defective. If it wont clear after a hard battery reset. I'd return it. Far as I know OE use Continental water pumps.
      11-10-2014, 01:55 PM   #5
ferocity02
Drives: 2013 135is
VDO were OEM pumps, but the latest version of the pump is made by Continental.
2013 135is DCT Carbon Black Metallic
