Modifying Exhaust Valve?
11-04-2014, 06:11 PM | #1 |
17
Rep 167
Drives: '07 E92 335i M sport 6MT
Hey guys,
I have an '07 E92 335i with the exhaust valve on the drivers side pipe of the muffler. I was thinking today, is there any way to mod the flapper to work with the touch of a button? Instead of the computer opening it under load? I was only curious because I would like to remove the resonator in my exhaust and I feel like that would drone considerably, so I'd like to have some control over the drone. So if anyone has ever tried this/has some insight, let me know! Alex
'07 E92 335i "M Sport" 6MT
Sparkling graphite metallic/black. De-badged, Black window trim, 35% tint all around, black kidneys, LED side-markers, M3 Side Skirts, Lip spoiler, M-Tech front lip, LED Angel Eye Bulbs, Clutch delay valve delete, K&N Drop in filter, Golf Tee Mod, BMS DCI, Custom Bren Tuning modified stage 1 map |
11-04-2014, 06:21 PM | #2 |
533
Rep 2,872
Unplug the connector in the trunk, search for the DIY. Plug the vacuum line (Golf tee mod), or the JB4 has a function you can select to automatically open the flapper each startup, regardless of RPM.
BSM E90 6MT-JB4 G5 ISO-BMS DCI-Golf-Tee Mod-Hankook S1N2 Non-RFT-ER Chargepipe/TiAL BOV-E40 blend-VRSF V2's-M3 CDV-MHD/JB4 FLASH-VRSF 5" STEPPED FMIC
11-04-2014, 09:30 PM | #3 |
17
Rep 167
Thank you for the input. However, I want to change it on command. So let's say I'm pulling up to my driveway late at night I'd like to just press a button and the valve will close. Right now I have it unplugged and I love the sound, just too quiet for my liking! Like I said, I plan on removing the resonator and adding an X-pipe and eventually downpipes. I know the flap in the muffler won't do too much but a nice feature.
11-04-2014, 09:39 PM | #4 |
64
Rep 263
The JB4 is as close to what you want as it gets. Takes 3 seconds to open or close it via steering wheel controls.
2018 340i F30 Xdrive
11-04-2014, 09:49 PM | #5 |
17
Rep 167
Go figure I'm running cobb!
11-04-2014, 10:00 PM | #6 |
421
Rep 1,643
I think I remember an actual product doing just this, posted here a couple years ago. It was a button that turned the flapper open or closed. The poster was ridiculed due to the cost of the product, I think like $200 bucks or so, since the money is better spent elsewhere.
2007 E92 335i MT
11-04-2014, 10:13 PM | #7 | |
17
Rep 167
11-04-2014, 10:39 PM | #8 | |
148
Rep 1,100
So if you have it plugged in, it should be closed unless you're going at it over 2.5k rpm, which you shouldn't have to going in/out of the driveway, at least in my experience. If you're so worried about noise, then just leave it plugged in. No point in having a switch to turn it off and on since it's barely noticeable anyways.
2010 335i Coupe- Monaco Blue Metallic
11-04-2014, 10:52 PM | #9 |
533
Rep 2,872
You could make things interesting and run an electric cutout along the line somewhere, I'm not being realistic I don't think, but it would be loud as hell if it were before the secondary cats with catless DPs
11-05-2014, 07:37 AM | #10 |
Guest
Rep n/a
Drives:
11-06-2014, 09:39 AM | #12 |
I Can't Drive 55
129
Rep 883
Drives: 2008 BMW 335i (E90)
Garage List 2023 VW ID4 Pro [0.00]
2002 Ford F250 7.3L ... [9.50] 2008 BMW 335i [0.00] 2012 Mercedes ML350 [0.00] 2002 Toyota MR2 Spyder [0.00] |
As FCorbra94 noted above, you can install an Exhaustmeister in your 2007 E92, which you can find HERE.
It was one of my 1st mods and I love it. Got a lot of sh*t about it in THIS THREAD that I posted about the install from guys who think it's a waste of $ because you can just put a plug in the tube (golf tee mod) or just disconnect the vacuum switch plug. But, those fixes can (but not always) result in a visible CEL (although there are probably still shadow codes being recorded) and aren't as convenient as just pushing a button to get the job done. The ExhaustMeister comes w/a little remote that will allow you to open and close the exhaust flap w/a push of a button but I programmed it in my E90 so that I can use 2 of the 3 buttons on the mirror to do that instead. I seldom bother to close the flap (even when driving long distances) because the noise doesn't bother me BUT it's easy enough to do once you've programmed the mirror buttons, if that's what you want to do. I just push the buttons occasionally to make sure they're still working. Installation in my 335i E90 was a bit of a PITA because I had to buy some interior panel removal tools to get the interior edge guard off (which was stuck tight) before I could get to the vacuum switch plug (where the Exhaustmeister is installed) and had to by some new plastic pop rivets to replace the ones that I broke in the process. However, I don't believe that the E92s have the same interior panels and that it's much easier to access the vacuum switch in the E92 as a result. Good luck!
2008 Black Sapphire 335i E90 Sport & Premium Pkgs - Cobb Stage 1+FMIC Sport map, Mishimoto FMIC & Alpina B3 AT Flash. See: My Build Thread.
11-06-2014, 03:00 PM | #13 | |
17
Rep 167
Do you happen to have any sound clips with the valve opening and closing?
11-06-2014, 03:01 PM | #14 | |
17
Rep 167
11-06-2014, 04:08 PM | #15 |
I Can't Drive 55
129
Rep 883
You're welcome! Enjoy!!!!
11-06-2014, 11:33 PM | #16 |
278
Rep 5,062
Drives: Black e92 335i
I made a thread about doing this a couple years back.
You could use parts from radioshack and do it for less than a case of beer probably.
JB4 / OSS Angel Eyes / Downpipes / F1-Racewerks FMIC / Custom Meth Kit / BMS DCI / ER Chargepipe / HKS BOV / BMS Meth Elbow / BMW Performance Exhaust / Carbon Fiber Inlay Quad Tips / 19" Miro 111 / Front Aero Lip / M3 Sides / VRS CSL Trunk / Mtech Rear / DD CF Quad Finned Diffuser / LCI Tails / BBK / Smoked Reflectors / F1 Euphoria LED Interior / License LED's / GT 5000k Corners / 5000k HID Fogs / Air Scoops / LED Turn Signals / FK Silverline Coilovers / HPA endlinks / Vibrant Resonators / Osram CBI 5000k D1S
11-07-2014, 12:31 PM | #17 | |
I Can't Drive 55
129
Rep 883
They'll pay $2-3k for new wheels and tires or about $1k in paint and parts to put on a new M bumper or $5k for a Big Brake Kit or $3-4k for suspension parts BUT when it comes to the exhaust flap, they don't want to pay more than a few cents for a golf tee or clamp to close off the vacuum tube or nothing at all to disconnect the vacuum tube switch connector, which is real tacky and cheap ass way of dealing w/the problem. Now you're saying that it's better to go to RS and buy some parts for $10-12 bucks and rig up an electronic switch of some kind to do it yourself? Of course, that begs the question of whether anyone else has sufficient knowledge to to it themselves. I, for one, do not know how to rig up such a device and I don't think most other guys here do either. BUT, even if I had the information, I personally wouldn't want to spend the time to do it. Why bother when I can just buy a device that's already been built and just install it? The guy who designed the Exhaustmeister knew what to do and how to do it AND is charging only $109 ($119 for later models) for benefit of that knowledge; that's called free enterprise. The cost of the device is NOTHING compared to what you'd have to pay for a variety of other mods on a 335i. In fact, that's about what BMW charges for a new OEM automatic shift knob or what you'd have to pay for a pair of WeatherTech floor mats. So, forget about it! Some of us would rather just buy a properly built part for a reasonable price, which does what it's supposed to do in a simple and elegant manner. I did and I don't regret it and I don't think the OP, AW55, will either.
11-07-2014, 12:49 PM | #18 | |
3441
Rep 79,211
I got a similar product on my vette, it's great. On the BMW it's not that much different in sound, there is a difference but not by a considerable amount. I personally just plugged the line and called it a day. On the vette it actually has a straight pipe through 2 tips that have the butterfly valve, so when it's open it's a straight pipe. When you close it it runs through just outer tips which go through the mufflers. |
11-07-2014, 03:49 PM | #19 | |
278
Rep 5,062
You seem to type pretty long and emotional replies anytime exhaustmeister comes up. I'm not sure what you have to gain or if you're involved with the product, but I rigged up my idea before I knew exhaustmeister existed. Just offering a very simple and easy alternative. I know nothing about electronics and after reading online I realized all you need to do is go buy a switch for a couple bucks and wire it in and you have a 3 dollar exhaustmeister.
11-07-2014, 11:42 PM | #20 | |
I Can't Drive 55
129
Rep 883
You've posted twice to say you've got a cheaper DIY option BUT I have yet to see the thread or schematics. If you want to do something other than just yank my chain on this topic and actually want to be useful to others, you should re-post the info (or a link to the info) about your $3 DIY device so that those who are interested can actually build it. Ciao!
11-10-2014, 08:41 AM | #21 | |
Guest
Rep n/a
Drives:
11-10-2014, 02:11 PM | #22 |
11
Rep 60
I always thought it would be cool to have a three way switch. One leaves it open (basically disconnect the current going to it so it's always open) one leaves it stock (closed on warmup open on accell etc) and another always closed ( would assume 12v going to circuit)
Anyone know if it's activated by 12v? Suppose I should just go out there with a multimeter and start playing with it. A 3 way switch isn't a whole lot of cash, so it could be a cool mod. |
