11-03-2014, 08:50 PM | #1 |
75
Rep 179
Road Feel
I hear and read about this car having zero road feel through the steering wheel. Is that an accurate statement?
It makes zero sense to me that BMW would eliminate the feel of the road when driving. Should I be worried? |
11-03-2014, 08:52 PM | #2 |
10783
Rep 8,852
Drives: '15 SO M4/'20 Z4 M40i
How many EPS threads are we going to have? We have been beating this to death for the last week already.
Tejas Chapter, BMW CCA, mem #23915, President 27 years, www.tejaschapter.org
11-03-2014, 08:54 PM | #3 | |
75
Rep 179
11-03-2014, 08:57 PM | #4 |
196
Rep 1,248
No and no. The F80 is the best M-car I've owned. (see my sig)
11-03-2014, 09:00 PM | #5 |
10783
Rep 8,852
http://f80.bimmerpost.com/forums/sho...light=steering
http://f80.bimmerpost.com/forums/sho...light=steering Totally agree. I don't have the problem with steering feel. I guess I am just not a good enough driver to notice the problem
11-03-2014, 09:00 PM | #6 |
344
Rep 2,928
Drives: 328i, 335i, M3, 535i, X5, 36M
Garage List 2014 Ford Raptor [0.00]
2012 328i E92 [10.00] 2013 X5 [0.00] 2013 335i F30 [8.00] 1990 Toyota Previa [0.00] 1997 E36 M3 [10.00] 2011 E92 M3 [0.00] 2011 535i [0.00] |
What the heck do they mean by road feel?
Is it that vibration that I felt on my e92 steering wheel when going straight? Because I felt vibrations going over rough pavement then it all went away when I changed out the tires for new ones. Is this what they mean by "road feel?" |
11-03-2014, 09:01 PM | #7 |
5457
Rep 7,037
BMW has done the best they currently can with EPS. Everyone is going EPS, HPS is in the past, there is no way back. It is what it is and the F8X steering is far better than other BMWs with EPS, progress is being made. Some of us don't like it (EPS) but it's a matter of take it or leave it since no new cars will have HPS.
11-03-2014, 09:02 PM | #8 | |
11825
Rep 15,400
You would have to be completely paralyzed not to have a feel with this car. Now, Op, go read the sex thread and you'll get the questions we can not answer going in your head.
11-03-2014, 09:20 PM | #9 |
21115
Rep 20,741
Drives: 2021 911 turbo
11-03-2014, 09:21 PM | #10 | |
104
Rep 680
11-03-2014, 09:30 PM | #11 |
8
Rep 199
I just test drove the new m3. The car is very fast and has precise steering. The only concern I have is the responsiveness of the engine but this will only be a problem If you use to previous m3's. I've owned every generation except the original e30 and I'm used to high revving naturally aspirated engines. If your ok with turbos, you will enjoy this car.
2015 PORSCHE CAYMAN GTS 6SPD MANUAL ON ORDER
01-02-2015, 10:38 AM | #12 |
10134
Rep 8,612
A little bit off topic... but does anyone know what rear subrame bolts directly to the car actually means?
I have looked at pictures and cannot figure out the difference between a normal 3 series. The car still has bushings... do they just mean solid bushings instead of rubber? I hope not...
2 x N54 -> 1 x N55 -> 1 x S55-> 1 x B58
01-02-2015, 12:02 PM | #13 |
///M Uber Alles
332
Rep 1,601
Road feel to me refers to two slightly different concepts.
One is the ability of the car's chassis, tires and steering to communicate the texture of the road surface on which you are driving through the steering wheel. The other is being able to sense the limits of grip going around a corner. Having driven a F82 over a wide range of road surfaces - dry and wet concrete and asphalt, gravel, ice, snow and my own winter street, which at times resembles the surface of the moon - I can say confidently that road feel in the F82 is not as good as it was in my e90 HPS system. That being said, I believe it to be leagues better than other EPS systems I have driven and communicates just enough road feel as a driver needs to drive well. Everything else about the EPS system, however, especially it's ability to, well, steer accurately and precisely as you intend is far superior to anything I have driven before. In short, it is not quite sex without a condom, nor sex with one. It's somewhere in-between that still allows one to be a good lover of the road.
die Welt ist meine Auster 2015 M4, MW, Black Full Merino, DCT, CCB, Adaptive M Suspension, Premium, Executive. Technology, ConnectedDrive, CF Trim, Convenience Telephony, European Delivery |
01-02-2015, 12:54 PM | #14 | |
590
Rep 5,396
01-02-2015, 04:13 PM | #15 | |
1030
Rep 1,190
Suspension components are mounted to the subframe with rubber bushings, and the subframe is also mounted to the body with rubber bushings. You can see the bushings clearly in this pic, those coke-can sized things at the left most end, and the two things above the differential. These bushings reduce vibration and add compliance to make the ride and NVH better at the expense of handling precision and drivetrain response. The M3 does not have these large subframe bushings. Also, rubber bushings come in a million different flavors. The M3 and 335i bushings may look the same, but the rubber stiffness or shape of the molded rubber could result in a bushing that performs very different. The M3 and 335i probably have a completely different bushing set up.
2015 M3, 2005 330i ZHP, 2015 228i 6MT Track Handling Pack, 2007 M Coupe (Sold)
01-03-2015, 10:53 AM | #16 |
10134
Rep 8,612
Thank you, I appreciate the response. I do understand everything... I must have been looking at some incorrectly tagged images as there were clearly bushings in those. If there are none, then the explanation is clear.
01-03-2015, 11:26 AM | #17 |
262
Rep 658
Only reason I can't feel the road is the G force making me light headed from the brutal acceleration and lateral grip.
2015 Alpine white M4\black leather, carbon fiber trim,manual,exec package, 19 inch black rims, M suspension, HK stereo, LED lighting
