In cabin smell
11-02-2014, 06:05 PM | #1 |
Warrant Officer
375
Rep 1,341
In cabin smell
Has anyone had a slight burnt oil or fuel smell from inside the cabin when the vehicle has become stationary? I've been getting this brief smell for 2 weeks now, but it happens off and on, and only when my car is at full temps. I took it into the dealer, and had them diagnose it. Pressure smoke tested the exhaust 3 times, and checked the EGR. They found no leaks. What other components should I check to see what could give off this fume.
This isn't a DPF regen, I know what that smells like. Car has 82k miles. EGR blocked for 10k miles after the CBU cleaning.
Deleted, ATM I/C and tuned by B.R.R.
11-02-2014, 08:01 PM | #2 |
20
Rep 59
Yes, my 2009 has that problem now. For me it's two part...
1st is the DPF differential pressure sensor tube, one burnt and was causing a cel and the smell. 2nd is an exhaust leak somewhere near the front of the engine, I can see the smoke with bright flashlight, but haven't located the source yet. I think it's at the flex joint on the EGR. I will find it and post when I fix it. |
11-02-2014, 10:23 PM | #4 |
Warrant Officer
375
Rep 1,341
Would it always cause a CEL though? I don't have any codes related to this issue.
Would this also cause excessive DPF regens? I am seeing a regen every 200-300 miles now.
11-03-2014, 04:37 PM | #5 | |
Warrant Officer
375
Rep 1,341
Thanks. |
