Bad dme what are my option?
10-31-2014, 03:57 PM | #1 |
18
Rep 195
after diagnostics shop says i need a new dme and its around 16-1700$ from the dealer,is that my only option?any help is appreciated as i dont even have enough money to fix the car right now.
2008 335i coupe 6MT BOOST FIEND
11-03-2014, 12:05 PM | #4 |
15
Rep 156
Drives: 2007 e92 335i
If the hardware is not damaged I think it's fine. I had my DME flashed back to stock for I believe 75 from an independent bmw tech.
BMS
451whp/489wtq @ EAS |
11-03-2014, 09:51 PM | #5 |
124
Rep 1,151
Drives: 10 e90 335i
If the mosfets are fried, they can be replaced pretty easily.
JB4, DP, VMR V710, Sonic Tuning S1 coilovers, Hybrid Ovations, Soundsplinter 10" and Zapco DC Ref amps |
11-04-2014, 01:12 AM | #6 |
184
Rep 1,702
Drives: Audi TTRS, 335is
Post what codes you are getting. If you are getting a 30BB or 30AA, then it's the MOSFETs and repairable as others have mentioned. There is an excellent post here:
http://www.e90post.com/forums/showthread.php?t=734162 If you are not up to repairing it yourself, a few of my friends locally found a local TV repair guy to replace the MOSFET for 20-30 bucks. Took him all of 10 minutes to do it. The MOSFETs themselves are relatively cheap as well. |
11-04-2014, 07:24 AM | #7 |
109
Rep 1,948
What year is your car? What's your mileage? Depending on that, you might have emissions warranty still on it and as the dme is covered by that, you could get it for free from Bmw. Double check your manual to verify. Up here in Canada, we have 8year/130000km emissions warranty. I just had mine replaced 8 months ago under that. Bmw honoured that and I was out of the regular warranty.
11-04-2014, 10:46 AM | #9 | |
171
Rep 347
11-04-2014, 12:37 PM | #10 |
184
Rep 1,702
Not sure why they go bad but its more common in 07s and some early build 08s. There was actually a TSB from BMW for the issue at one point. Three of my friends have had the same issue in recent months.
11-11-2014, 03:56 PM | #11 |
18
Rep 195
UPDATE
DME is fine the issues was diagnosed by BMW tech to be some loose pins in the dme connectors.and a bad exhaust cam sensor so the car is now running.
11-11-2014, 03:57 PM | #12 | |
18
Rep 195
11-11-2014, 04:11 PM | #13 |
533
Rep 2,872
11-11-2014, 05:27 PM | #14 |
291
Rep 2,189
Nice!
2007 E92 335 6MT w/335is clutch FBO MHD E60 Wedge map 49k miles
11-12-2014, 07:12 PM | #16 |
18
Rep 195
this was cause during the procede re installation,now im scared to try to re install dammmit lol
