proTUNING Freaks
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Suspension | Brakes | Chassis
      10-31-2014, 01:21 PM   #1
Pat@sonictuning
Pat@sonictuning's Avatar
370
Drives: Porsche 996 Turbo
Lightbulb New AP Racing FORGED Radi-Cal Brake Systems for F8x | 390MM
AP Racing, the leading manufacturer of performance braking and clutch systems, for road and race use, has created a new range of Radi-CAL™ brake calipers, which incorporate race technology into high-performance road products. AP Racing's Radi-CAL racing calipers have taken the racing world by storm, dominating the highest level racing series on every continent.
The pressure forging process results in a strong, stiff caliper that is 20% lighter than similar cast calipers. Each caliper has been tested with over 500,000 cycles of pressure and torque to meet AP's stringent quality standard. The non-symmetric design is the result of Finite Element Analysis testing to determine where weight saving can be achieved without compromising strength and stiffness. Radi-CAL calipers are double sealed for durability. Hard anodized aluminum pistons are differentially sized to maximize pad life. A removable forged Bridge allows for easy pad changes. Anti-rattle springs prevent pad movement and knock back.
Available as six and four-pot front calipers, as well as a four-pot rear caliper, the new range of Radi-CAL™ products distil the company’s expertise in producing brake systems for race and OEM installations, into calipers suitable for the aftermarket. As a result Radi-CAL™ delivers an advanced brake upgrade for the owners of high performance and sportscars.
Featuring a two-piece aluminium body and h-piece, the forged non-symmetrical calipers offer a significant reduction in mass compared to conventional designs, and improved efficiency when resisting the torque generated by braking. This not only lowers a vehicle’s un-sprung weight, but also ensures continued high performance in demanding applications.
AP Racing’s advanced design process allows the concept to minimise structure and weight, while improving caliper cooling surface area, without sacrificing rigidity. This provides improved brake caliper cooling and reduces disc temperatures during high performance driving.
The Radi-CAL(tm) calipers feature a highly durable paint finish featuring the distinctive new Radi-CAL(tm) logo, and available separately or with matching performance road-car discs and pads for specific customer requests. The Radi-CAL(tm) Factory Big Brake kits incorporate floating two-piece disc assemblies, and include bespoke mounting bracket and bolts, a braided hose kit and DOT 5.1 high temperature brake fluid.
Includes
D701 Ferodo DS2500 Brake Pads
AP J Hook Rotors
Custom Goodridge SS Line
Optional AP Racing, Street, Semi Track, Track brake fluid.
Application
F8x M3 APR7140 Front 390x36mm 6P
E9x M3 APR7130 Front 370x36mm 6P
E9x M3 APR7170 Rear 380x28mm 4P
Studie AG Shop Car– They ran AP Radi-CAL on their M4 at Suzuka Circuit:
      11-03-2014, 06:18 AM   #2
Pat@sonictuning
370
Pre Sema bump!!
      11-06-2014, 05:43 AM   #3
Pat@sonictuning
370
SEMA Bump!!
      11-06-2014, 06:24 AM   #4
jackkk
jackkk's Avatar
Russian Federation
73
Drives: M3 F80
Nice! How much for the 390 front 380 rear set up? Will it be okay for the 18 stock rims?
F80 M3 SO/SO |BM3 St.1 91 oct.|Cattless DPs|Tractive P'n'P|Brembo 6pot|Rays G25 with CUP2 tires|GTS coding|
1M VO FBO (KW DDC) PTF st.2+ sold
e90 335i FBO jb4 sold
      11-07-2014, 07:15 AM   #5
Pat@sonictuning
370
PM sent
      11-10-2014, 05:44 AM   #6
Pat@sonictuning
370
AP bump!
      11-10-2014, 10:44 AM   #7
Brosef
Brosef's Avatar
Drives: F90 M5
any other info on the weight of the calipers and rotors vs. the stock steel units? also, what pads are available? any chance we could get more installed pictures?
thanks in advance. if you could also PM me pricing, I would appreciate it.
      11-10-2014, 01:07 PM   #8
Pat@sonictuning
370
The rotors and calipers will probably weigh a little more than OEM due to the size of the kit. However, the stopping power of the kit is incredible. I will see if I can get anymore pics.
      11-10-2014, 01:21 PM   #9
Wei718
Wei718's Avatar
340
Drives: 718 GT4
Can I get a set in blurple?
      11-13-2014, 06:05 AM   #10
Pat@sonictuning
370
Hahahah funny!! Anything for you .
      11-17-2014, 09:17 AM   #11
Pat@sonictuning
370
Monday bump!
      11-26-2014, 08:18 AM   #12
Pat@sonictuning
370
      11-26-2014, 12:35 PM   #13
pdudek
Drives: BMW M4
Can I get some additional info for future budgeting?
Also would be interest in replacement parts
      11-28-2014, 10:15 AM   #14
Pat@sonictuning
370
What type of information can I provide you sir?
Tags
f80 f82 ap racing, m3 m4 radical bbk
f80post
