JB4 2-step/NLS install problem
10-31-2014, 10:20 AM | #1 |
Rep 85
So I installed a new JB4 with meth and the 2-step/NLS relay. The JB4 works and the meth works but the 2 step does not. I have set the RPMs above 2000 and mash the pedal to the floor but all it does is rev all the way up never stopping at any limit I try and set it to. Its getting power because the three things are all piggybacked as shown in the install guides. I followed everything to the T but no love from the car or the relay. Anything I might have missed or is there a trick to getting it to work? Seems straightforward as were the other installs but strange that only the relay wont work.
The white and blue wires off the relay are supposed to be together correct? |
10-31-2014, 11:01 AM | #2 | |
321
Rep 710
Drives: 23 M3 Competition
http://www.n54tech.com/flash_files/n54_nls_install.pdf
14 F30 N55 AWD SpeedTech EFR-8374, E70 MHD, Motive tuned
23 M3 Competition - Stock |
10-31-2014, 11:51 AM | #3 |
Rep 85
Yeah I did, Ill have to double check all the connections this weekend. I did all three at the same time, maybe something got overlooked. Ill report back on my findings.
11-01-2014, 07:29 PM | #4 | |
Rep 150
2008 335i Coupe TiAg - Cold Weather - Premium - Sport - Style 230 19's - SatNav - Active Steering/Cruise - Comfort Access - PDC
11-03-2014, 07:06 AM | #5 |
Rep 85
11-05-2014, 11:02 AM | #6 |
Rep 85
Tried setting Future use D to 14 and 100 as suggested. No dice.
Pedal signal shows 100 when mashed, low pressure setting shows 0 to 1 when Future Use set to 14 as noted in the install. Last step is to touch the twisted pair to a ground to see if the car begins to stall. Will try it this weekend. |
02-15-2019, 10:49 PM | #7 | |
Rep 41
03-05-2021, 10:22 PM | #8 |
21
Rep 128
Did you press the clutch at the same time? the instructions say you need to have the clutch pressed in for the feature to work
"NLS will cut engine power above the 2-step RPM set point when pressing the clutch while the gas is fully pressed"
CALIFORNIA SMOG LEGAL |
