RPM rising to 750??
10-29-2014, 06:52 PM | #1 |
43
Rep 420
RPM rising to 750??
hello everyone i need some help!
so recently my car starting to act funny... meaning when im on idle (neutral, park), rpm would rise to 750 from from 600. it feels like the engine would jump like misfire? but its not throwing any codes!!! i've changed spark plugs about 20k and coil at 88k. Currently, my car is at 92k. i think its the injector or fuel pump but without codes i dont think i can get it replaced (i do have 3rd party extended warranty). Has this happend to you guys as well?? if yes what did you do to get it fixed? and is there anyway i can check if injector and fuel pump is leaking? Thanks! BTW my car is 2007 e90 335i (auto) here is the video (sorry ive took this when the rpm already rise to 750) |
10-29-2014, 07:12 PM | #2 |
53
Rep 398
Do a search of misfire at low rpm idle.
There seems to be quite a few cars experiencing this type of problem as of late, myself included. To check if the injectors are leaking, start the car for a short period and then remove the spark plugs to check for any fuel present(smell of fuel) on the tips. This indicates a leaky injector. General consensus is the car will usually run as normal with no reduction in performance at WOT. Grab a couple datalogs to confirm. |
10-29-2014, 08:15 PM | #3 |
533
Rep 2,872
Sounds dumb, but is your blower motor running? Does it happen when you have the A/C or heat OFF?
BSM E90 6MT-JB4 G5 ISO-BMS DCI-Golf-Tee Mod-Hankook S1N2 Non-RFT-ER Chargepipe/TiAL BOV-E40 blend-VRSF V2's-M3 CDV-MHD/JB4 FLASH-VRSF 5" STEPPED FMIC
10-29-2014, 09:49 PM | #5 |
43
Rep 420
