10-29-2014, 03:03 PM | #1 |
16
Rep 94
winter is coming!
Folks,
This will be my first Minnesota winter in my F30. What tips/suggestions can you give me to keep the car healthy, safe and running at sub-zero and icy conditions? My car is 2014 335i AWD with the default all weather tires appreciate your help! |
10-29-2014, 03:24 PM | #2 |
197
Rep 2,802
Winter tires. AWD wont help you stop. It will be a beast!
10-29-2014, 04:00 PM | #3 |
16
Rep 94
sheeeeeeeeeet! I live only 4 miles from my work and i am not planning on doing a lot of driving in next 3-4 months. are winter tires absolutely necessary? if so, can you give me some good recommendations? I am also more concerned about the road salt rusting the car, undercarriage and stuff. |
10-29-2014, 04:24 PM | #4 |
205
Rep 555
Tires always make the biggest difference, esp w/ stopping, turning, etc. Given your short commute and if most of your driving will be after the streets are plowed, you'll probably be ok w/ the awd & all seasons. As for the road salt, just wash or spray it off when you get a chance. A good waxing before the winter season also helps.
Boston CCA 383036
'20 M340i '18 MB GLS550 '07 4Runner V8 Limited 4WD |
10-29-2014, 04:59 PM | #5 | |
472
Rep 1,659
Drives: 2022 WRX World Rally Blue
Rick
10-29-2014, 05:01 PM | #6 |
38
Rep 64
Only 4 miles one way to work, better get a trickle charger for the battery, you will most likely get low battery level warning, unless you do some long distance drives over the weekend.
10-29-2014, 05:05 PM | #7 | |
38
Rep 596
I would also recommend winter tires, well depending on where you live. We get a lot of snow in upstate NY, so I am definitely getting a dedicated winter setup (tires + wheel + tpms). OP since you're from Minnesota, I'd recommend it. Also, just take your time driving, and give yourself plenty of time to get to your destination.
2013 BMW 335i xDrive Sport Line
10-29-2014, 06:47 PM | #9 |
17
Rep 164
I always ran 4 winter tires and never had a problem in the snow. Salt was always a bigger worry for me. Kept it hosed off best I could. Lucky I have a heated garage, made it easy.
10-30-2014, 09:02 AM | #10 |
197
Rep 2,802
You will go through 2 sets of tires in the life of the car so why not make one of them winters?Not costing you any more...youre just buying second set early. Endless videos about stopping distances. has a lot to do with temperature, not just snow/ice. Its not close.
10-30-2014, 09:24 AM | #11 | |
4067
Rep 4,984
If you think you'll be able to avoid hills and poorly paved/traveled roads, an AWD system with all-seasons will serve you well as long as you don't expect to drive as you do the rest of the year. That's been my approach and it's never failed me. Best of luck.
<b>2023 M5C SRG|Aragon || 2018 Macan GTS</b>
2019 F90 Comp MBB|Black (sold) 2018 F80 ZCP TB|SS (sold) 2015 F30 335 AW|CR (sold) 2015 F31 MG|CR (sold) 2011 E90 JB|Oyster (sold) |
10-30-2014, 09:24 AM | #12 |
253
Rep 1,003
Drives: 16 340i, 15 X3d, 91 318i
Make friends with your closest coin-op self-serve car wash bay place(s), and give the car a thorough rinse top to bottom, underneath, and in the wheel wells whenever the temperature permits (35+ or perhaps a tad lower if you have a garage). While you're at it, wash it if you're willing. Some people get away with it, but I believe those who just let the car accumulate dirt all winter are those whose cars will oxidize and push the boundaries towards rust after a few years, undercarriage or otherwise. Washing a car isn't just for vanity, it's preventive maintenance. I've washed with snow on the ground many times.
10-30-2014, 10:54 AM | #14 |
2197
Rep 2,558
I live in Boston and had dedicated snows on my S4 and I thought they were overkill. With AWD and all seasons in an environment where there is at least occasional plowing during a storm you will be able to do everything you need to do. My experience has been that AWD with all seasons is better at climbing hills especially from a stop than RWD with dedicated winters. I get the cornering and braking advantage of the snows but honestly out on the roads i never had an opportunity to take advantage of it with everyone else doing 5-10mph on FWD or RWD with all seasons traffic moved really slow every snow storm. if you are looking to cruise the backcountry then go for the winters, if you are just looking to finish the commute home my opinion is all seasons will be fine. having done on previous vehicles RWD with all seasons, RWD with winters, AWD with all seasons, AWD with winters, I am 100% fine with just using the stock A/S on my 335 xdrive this winter.
Now if you got a vehicle that came with dedicated summers like my S4 did and dont want to drive on all seasons year round so are planning a separate set anyway for winter then getting winter tires is a no brainer. but changing out A/S on an AWD car in most situations is unnecessary just my thoughts |
10-30-2014, 12:01 PM | #15 |
197
Rep 2,802
there it is again "you'll be fine".
http://www.caranddriver.com/columns/...ur-wheel-drive http://jalopnik.com/lets-settle-the-...bat-1462180324 You probably won't believe this. These are facts. |
10-30-2014, 07:32 PM | #16 | |
2197
Rep 2,558
10-31-2014, 08:56 AM | #18 |
4067
Rep 4,984
The second video pits an AWD against a 2 wheel drive, summers vs snows. The OP has all seasons. I would argue that it's really not a huge difference (snow vs summer and snow vs a/s), but you can get by with all seasons, whereas summers will be worthless.
10-31-2014, 09:29 AM | #19 |
307
Rep 1,747
I'm going to try to get through this Winter as spunty does....on A/S with xDrive. Our LR4 on A/S has never had a problem in snow. I had a RWD with performance snows last year and it was a white knuckle drive whenever there was more than an inch on the ground.
I'm sure if I got Blizzaks on my xDrive, it would be worlds better than summer tires and probably better than the A/S Conti's I have now. I'm just hoping to get through the season so I can spend the money on a new set of 19" wheels/summer tires instead. Eventually I'm hoping to replace the A/S RFTs with dedicated snows on my current set of 18"s. |
10-31-2014, 09:36 AM | #20 |
253
Rep 1,003
10-31-2014, 10:01 AM | #21 |
197
Rep 2,802
He is calling them summers but look at them...they are a/s. Does any manuf put anything but a/s on an suv? Its about temperature and stopping. "not having a problem" in LR with a/s ? You'll stop way shorter on proper tires. I'm out.
10-31-2014, 12:45 PM | #22 | |
4067
Rep 4,984
