Low boost, fault codes 30FF and 2C7B, related?
10-28-2014, 06:37 PM | #1 |
Rep 92
I have low boost as well as the oxygen sensor fault code, is the oxygen sensor causing the low boost ? It's an after cat sensor so I don't believe so or is it just a coincidence that both codes popped up? Or by product?
I figure the low boost is a vacuum line but I've only went over what's readily available at the surface and not under the engine. Any help is appreciated! Thanks. |
