Side effects from running x-kitty 24/7 ?
10-27-2014, 11:41 PM | #1 |
57
Rep 272
Does anyone know if their are any side effects from running the x-kitty 24/7 . I've been searching for a while but haven't found anything saying if it doesn't matter or if it's not recommended . Any help will be greatly appreciated
FBO , MHD , tuned
10-28-2014, 01:19 AM | #2 |
BimmerPost Supporting Vendor
1334
Rep 1,701
Drives: Slot Machines.. Keep Taking $
I wouldn't run it all the time. It's my understand it can cause issues with fueling.
I thought about making a cut out switch so you can turn it on and off, but after looking at the parts and the additional time, no one would want to pay extra for something you will only use once every couple of years. |
10-28-2014, 02:14 AM | #4 | |
Jedi samurai ninja turtle
619
Rep 3,021
Drives: X3 M40i 2018
What is x-kitty? |
10-28-2014, 10:28 AM | #5 |
57
Rep 272
Thanks wedge . That's the first I've heard of any negative effects. I'll unhook it today . I've been running it for the last 4 months.
FBO , MHD , tuned
10-28-2014, 10:32 AM | #6 |
3072
Rep 4,393
Drives: 2022 F97 X3M Comp LCI
im assuming the dpfix.
many members and tuners have suggested no running dp fix (O2 sims) for too long as apparently they will mess with fuel trims. only run them for inspection only (O2 emissions/readiness).
BMW MY22 F97 X3MC LCI - CURRENT BUILD THREAD| Instagram: @danniexi
BMW MY16 F80 M3 - GONE BMW MY08 E92 335XI - GONE BMW MY06 E46 325XI - GONE |
10-28-2014, 10:32 AM | #7 |
533
Rep 2,872
10-28-2014, 11:27 AM | #8 |
530
Rep 2,083
If you cannot run a dp-fix for an extended period of time then how do you go about avoiding a check engine light? I thought it was something you would install with the dp's and never mess with again (until you remove the dp's).
2013 135is DCT Carbon Black Metallic |
10-28-2014, 11:41 AM | #9 |
64
Rep 553
You could flash tune it and remove it. I know OFT has this capability.
Montego Blue E90 335i
7" VRSF IC | OFT Tune | DCI | RB PCV | Secondary CAT Delete & CYBA 3.75" Tips | M3 Front | Mtech Rear | CSL Trunk | 219M | KW V1 | AA CP |
10-28-2014, 01:15 PM | #10 |
530
Rep 2,083
Ah I see. I know the JB4 will clear it with it's "autoclear" function but I don't want to enable it to avoid it clearing any other important codes that may pop up.
10-28-2014, 01:21 PM | #11 |
34
Rep 1,093
If you run two o2 sims you can get away with leaving it in 100% of the time. But the standard ones available only use 1 secondary signal for both banks so it will skew the fuel trims on one bank.
07 335XI (A008006) 6AT ~94K miles JB4 G5 ISO VSRF DP's
09 135I M (VK80379) 6MT. Race Project car. 1) Install Cobb/piggyback? and Motiv 600 Kit[HTA3076R w/ tial .82] 2) JRZ or Moton suspension. 3) Build high flow intake manifold with multi-port fuel and relocate OFH 4) Build full cage 5) Complete staged twin setup with HTA4205R [w/Tial 1.16] 6) Complete dry sump system |
Chris@VargasTurboTech1933.00 |
10-28-2014, 01:23 PM | #12 |
1334
Rep 1,701
10-28-2014, 01:45 PM | #13 |
13
Rep 384
So if I install catless downpipes and run two dp fixes I can leave them on 100% of the time won't have to worry about passing emissions testing, or the fuel problems? Will this also prevent any codes from popping up?
10-28-2014, 01:50 PM | #14 |
172
Rep 2,347
+1
that be sweet
Mods:-Berkexhaust -alpinaB3flash -CobbAP -Cobb FMIC -ER charge pipe tialQ bov -M3 front sway bar -M3 subframe bushings -M3 front upper and lower control arms -M3 guide rods -M3 rear upper control arms -Mfactory LSD -defiv lockdown kit -TC Kline SA coilovers /camber plates- HP rear toe arms |
10-28-2014, 02:05 PM | #15 |
292
Rep 1,473
OP are you referring to running catless DP's all of the time. If so, I have been running them for 2 years with no issue. I do not use the DP fix and I am only using Cobb and I always pass emissions. I am also in NC.
10-28-2014, 02:14 PM | #16 | |
57
Rep 272
FBO , MHD , tuned
10-28-2014, 02:17 PM | #17 |
292
Rep 1,473
It is not necessary to uninstall your DP to pass emissions in this state. I am not sure about JB4 but I would bet that it clears the code and puts the system in ready mode just like Cobb.
10-28-2014, 02:30 PM | #18 |
57
Rep 272
That's why I bought the xkitty , so I wouldn't have to uninstall the DPs . I will check my car with the Bt cable to see if it goes into the ready state without it and will let you know. Thanks you and everyone for your advice
FBO , MHD , tuned
10-28-2014, 02:33 PM | #19 |
57
Rep 272
I'm thinking about getting the cobb or the OFt so I can see which one I like best . I'm going to get the aquamist 4 in jan r feb and then all I'll need upgrade is the turbos. I'm waiting to see what RB comes out with b4 I make my decision
FBO , MHD , tuned
10-28-2014, 02:34 PM | #20 |
103
Rep 420
Well now I'm confused. I got some VRSF DPs recently and got their "dp fix" as well. I was planning on wiring it in and leaving it for good. So you guys are saying I shouldn't do this?
Lots.
10-28-2014, 02:37 PM | #21 |
57
Rep 272
Lol , I know the feeling . I would go ahead and put it on and get it dialed in , and then after u find the right setting take it off . That way when u need it you will only have to hook it up ( it will already be dialed in )
FBO , MHD , tuned
10-28-2014, 02:48 PM | #22 |
103
Rep 420
I don't want any CEL popping up, those annoy the shit out of me. Someone mentioned JB4 will clear it, but does it clear ALL codes or just the O2 ones? Clearing all codes sounds like a good way for something to break and me not know it, so I don't want to go that route either.
Lots.
