Question on adjusting hand brake?
01-03-2008, 04:05 PM | #1 |
Rep 15
hey all, I did a quick search, but came up with nothing....does anyone know how to adjust the e-brake? Is it a quick adjustment on the brake handle, or is it beneath the rear wheel? thanks in advance!
01-04-2008, 08:34 AM | #3 |
Rep 15
well ever since day 1 will this car it seems like my hand brake does not hold the car. i will pull it up all the way, and the car will still roll. so i will have to muscle it up another click or 2.
08-18-2011, 05:05 PM | #5 |
124
Rep 5,627
08-18-2011, 05:40 PM | #6 |
Freight Dawg
104
Rep 2,103
There is an adjustor screw behind the rear rotor. You do not have to remove it to get to it. Just remove wheel and rotate the rotor while looking in the lug holes (use a flashlight). You'll see a spur. Rotating the spur with a flat screw driver will adjust the brake. BE CAREFUL. I had someone adjust mine and it engaged while I was on the track! It didn't lock the brakes but it overheated the shoes and cracked the rotor hub. All bad! Have a BMW shop do this. BMW e-brakes should not engage on the first click.
--Marcelo
'06 Arctic Metallic 325i | Sport Package | 6MT | Dinan Stage III suspension | Dinan exhaust | 330i manifold swap! Click here! | Active Autowerke tune | 135i Brake Calipers | Deiselboost caliper brackets | E46 M3 front rotors |
08-21-2011, 04:23 PM | #7 | |
21
Rep 780
http://www.csfrancis.net/BMW/pbdiy.pdf |
