When do you guys start meth flow? And are my meth settings correct?
10-26-2014, 11:25 AM | #1 |
20
Rep 67
Hey guys,
I have the BMS meth kit with FSB installed on map 3 and I love it so far. I run 93 oct with a 50/50 boost juice mix. I set: Meth scale to 60 Meth add to 40 And start meth flow at 11psi My question is. Can I start meth flow at a lower psi safely? Or is 11psi low enough? I cant find anywhere what other users start meth flow at. And are my other settings correct? Thanks in advance. |
10-26-2014, 12:47 PM | #3 |
172
Rep 1,909
Mine is set to start flow at 4 psi. i know others who have set theirs lower.
Current: 2017 F30 340i xdrive
Previous: 2008 e92 335i coupe: RB turbos, mach 116 race fuel, methanol, alot of boost. Previous: 2003 Honda Accord V6 coupe: AEM V2, zex 75 wet shot (sold) |
10-26-2014, 01:00 PM | #4 |
226
Rep 2,387
Wow 4 is really low. Are you running map 3? What about your meth/water mix? I just installed my kit last week and still figuring out what is what. 91 octane and 50/50 meth/water.
10-27-2014, 06:24 AM | #5 |
172
Rep 1,909
its either 4 or 5 psi, i don't remember exactly. map 3, 70 additive. e85/93 mix and 100% meth. No issues and Iats are usually always around ambient on multi gear pulls.
10-27-2014, 09:45 AM | #6 |
677
Rep 1,349
Drives: BMW F80 M3
my meth starts flowing at 12 psi
10-27-2014, 10:12 AM | #7 |
100
Rep 1,040
Mine starts flowing at 8psi. Meth boost additive set to 65 since I am running around an E70 blend.
2009 335i M Sport coupe, BSM with black/aluminum interior, 6MT, JB4 G5, MDH Backend Flash, Walbro 255 inline LPFP, VRSF Inlets, BMS 3" catless DP's, Borla Aggressive catback, ER FMIC, ER charge pipe, Tial BOV, BMS 2.3 gal Meth Kit, BMS Sport Oil Cooler Valve, Ported CDV, RB PCV, Cyba ram air scoops, Status Gruppe SRS coilovers, ECS trailing arms, Forgestar F14 SDC.
10-27-2014, 10:48 AM | #8 |
ex deus machina
124
Rep 968
I believe the default is 12psi, according to BMS that’s when meth is needed/has the most benefit
I start mine at 6psi to reduce the lag between when the meth starts following to when boost is actually raised due to built-in safety algorisms I’m running Map 3 with 35 additive on 91 octane, meth:water at 80:20, single CM10 nozzle
Daily: G30 M550i, Bluestone, JB4, 1 step colder plugs, 6WB retrofit
Winter Beast: Audi S4 4.2L V8, Supercharger, brakes, suspension & exhaust mods Wifes': F15 M50d clone, DUDMD tune, WMI, MPBK Gone: E92 335i N54 468rwtq |
10-27-2014, 12:06 PM | #11 | |
3441
Rep 79,211
This platform and ECU is so sophisticated you can pretty much spray blindly and it will adjust fuel accordingly and we're not dealing with that high of a PSI. From an efficiency purpose you can spray with a progressive system but buying the components and calibrating the unit would yield no benefit except using a little less methanol if your inbetween those boost settings. I typically drive WOT or like a grandma so I just wanted methanol flowing fully and atomized by the time I hit 12 psi so I sprayed early so it could in essence "ramp up" to full bore by the time this car hit 12 psi. I ran as high as an M12 Nozzle with a 6 or 8 psi settings. I later set it to about 7 psi and ran an M5 and M7 nozzle for further atomization efficiency. |
10-27-2014, 12:28 PM | #12 |
226
Rep 2,387
OK now I am curious, what do you think is the reasoning behind recommending a higher level of boost to turn the meth on?
I need to do some baseline logs first but I like the idea of 6-8 PSI better than 11-12. |
10-27-2014, 05:19 PM | #13 |
Custom User Title
50
Rep 247
i see Jeff, makes sence thanks. I ran a prgressive systemon my last ride, which was a MKV Gti. I saw boost as high as 21psi so yes that makes sence LOL.
with this is anyone running 100 octane or race map profiles with this... spraying down low would make sence then.... |
10-27-2014, 06:39 PM | #15 |
4496
Rep 1,862
Drives: powered by bootmod3
Ideally you'd want to spray meth based on injector duty cycle, load and a number of other parameters. We only support tuning for meth with Aquamist HFS-4 kits that come with the best turbine based failsafe on the market today and it supports 100% meth in all sorts of climates unlike some other kits. It is hard to recommend the best boost level to 'start' spraying at as you're really not 'starting' (modulating flow progressively) to spray with a kit such as yours. As such, anywhere from 4-8psi has been done in the past.
Do yourself a favour and get an Aquamist turbine based flow sensor and wire it into the JB to monitor flow as accurately as possible. FSB is an electrical device that calculates flow based on current at the pump and doesn't see actual fluid flowing through the lines to the nozzles. Terry's added support for various meth flow strategies in the last year and we'd highly recommend getting this set up on your car especially if you're running an aggressive tune with meth compensating for fuel volume/octane limitations. Jeff is also right that our ECU, fortunately, is quite a forgiving one when it comes to fuel control as it will quickly adjust to changes in fueling due to meth. There are many other platforms that do this as well today having fuel controlled in a closed loop fashion. N54 is certainly no exception. Dzenno@PTF
YouTube Channel [NEW] | Facebook User Group (20,000+ members) | Tech Support Website | Wiki | FAQ | iOS App | Android App | bootmod3 Web
Sales Support Email: sales@protuningfreaks.com | Tech Support Email: support@protuningfreaks.com |
10-28-2014, 10:46 AM | #16 |
ex deus machina
124
Rep 968
at the track I run strait 100 octane on Map 3 with 75 additive, this setup maxes out the stock turbos
10-28-2014, 11:39 AM | #17 | ||
3441
Rep 79,211
There really is not 1 straight answer for methanol users. The most important aspect of methanol on this platform is atomization and even distribution between cylinders. I also don't believe as much any more in spraying methanol for maximum performance, it's too much of a band aid. When one is considering methanol, plan on spraying enough to keep the temps down and bump the octane but don't rely on it completely. Most importantly, be sure you can monitor all 6 cylinders of timing. Proper logging, tuning and maintenance of the methanol system is important. You should check up on your datalogs every month I would say and make sure everything is running smoothly. For some, this could be quite tedious, so if you have E85 in your area I'd go that route sooner. As I said before, consider just spraying meth on top of E85/or pump to keep the IAT down but only tune the vehicle for max performance on the pump gas, that way you can leave some headroom for safety. |
10-29-2014, 10:24 AM | #18 | |
Custom User Title
50
Rep 247
so with e85, you can mix that with regular pump gas..? is that what your getting at? i keep seeing this e85 stuff gettin tossed around, ive never ran it personally... |
10-29-2014, 07:46 PM | #19 |
Rep 538
The trick with spraying meth is that it's both a fuel and an octane booster at the same time, so it's almost impossible to use it just for the octane boost and IAT suppression without needing to tune for the extra fuel it provides. It's possible to only spray a small amount and keep the AFR rich so if the meth system runs dry or malfunctions the engine is still safe, but a small amount of meth only gives a small bump in power. Simply put, spraying more meth makes more power if you're tuned for it. That's why I recommend paying a few extra bucks and getting a good quality system. Meth is addictive to your car and at some point you'll feel the urge to turn it up, so do it right and stay safe.
