10-25-2014, 08:49 PM | #1 |
28
Rep 326
Help!! Dropped bolt in engine bay!!
My brother dropped a bolt in the engine bay while trying to install a new air filter. We haven't tried starting the car because we're afraid to in case it could screw something up.
It's now too dark to try to look for it but does anyone have any suggestions as to what to do?
///M4 | Alpine White | Sakhir Orange Leather | Carbon Fiber Trim & Roof | DCT | Black 19" Wheels | Executive Package | Driver Assistance Plus Package | Adaptive M Suspension | Enhanced USB | Parking Assist | Harman Kardon
10-25-2014, 08:54 PM | #2 |
343
Rep 2,928
Drives: 328i, 335i, M3, 535i, X5, 36M
Garage List 2014 Ford Raptor [0.00]
2012 328i E92 [10.00] 2013 X5 [0.00] 2013 335i F30 [8.00] 1990 Toyota Previa [0.00] 1997 E36 M3 [10.00] 2011 E92 M3 [0.00] 2011 535i [0.00] |
It'll probably fall out with continued driving. Or it gets caught in underbody shield
10-25-2014, 09:02 PM | #3 |
28
Rep 326
10-25-2014, 09:04 PM | #4 |
280
Rep 473
Take out the undertray because most likely the bolt should be sitting at the bottom or use a magnetic stick and poke it around the engine bay until it catches.
10-25-2014, 09:19 PM | #5 |
340
Rep 1,089
As suggested from above, remove the under tray and look for it. If you need to start the car don't worry, nothing will happen for a missing bolt from the intake box as long as the sensors isn't disconnected you will be fine.
10-25-2014, 11:42 PM | #6 |
Bored all the time
383
Rep 2,171
If you don't know the answer to this question, you probably shouldn't be working around the engine.
Current: 2014 991 Turbo RS
Past: 15 GT3, 17 R8 SC, Two 16 M4 GTS’s, Two 18 GT350R's, Two 13 RS5’s, 13 M3, 10 R8, 15 M4, 09 M3, 04 M3, 09 S5, 02 M3... It all started with an RX-7 (FD). |
10-26-2014, 05:14 AM | #9 |
1712
Rep 5,108
You really don't want a dropped bolt near the serpentine drive belt...
http://www.n54tech.com/forums/showthread.php?t=11957 The S55 should be similar to the above. Get a bolt in there and most likely the drive belt will snap... Last edited by Boss330; 10-26-2014 at 06:37 AM.. |
10-26-2014, 07:19 AM | #10 |
54
Rep 121
Drives: 2015 M3
S55 belts are a lot different without the power steering pump
10-26-2014, 03:01 PM | #11 |
1712
Rep 5,108
Good clarification and shows that the S55 has belts much closer to the airbox than the N55 (parts 8 and 9 are positioned towards the right hand side, while on the N55 all belts are on the left hand side)... Even more reason to be careful with loosing bolts down there
10-26-2014, 04:06 PM | #12 |
28
Rep 326
It was very nerve-racking but he finally got it with a magnetic stick and a flashlight!
